Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series & 4 Series
3 Series & 4 Series
The BMW 3 Series and 4 Series Forum. If you would like to see all new posts in all the forums, click here.
Old 09-30-2004, 09:51 PM
phita23 phita23 is offline
Send a message via AIM to phita23
Mein Auto: BMW 325i
Why Manual > Automatic?
Why, when all other conditions are identical, will a stick shift be faster than an automatic?
Old 09-30-2004, 09:58 PM
Pete Teoh's Avatar
Pete Teoh Pete Teoh is offline
Vegan, not Romulan
Send a message via ICQ to Pete Teoh
Mein Auto: ****
An automatic transmission uses a torque convertor which is not as efficient as a clutch in transmitting power from the engine to the driving wheels.
Old 09-30-2004, 10:37 PM
Jever's Avatar
Jever Jever is offline
call me darkcloud
Send a message via ICQ to Jever Send a message via AIM to Jever Send a message via MSN to Jever Send a message via Yahoo to Jever
Mein Auto: .
-Capitalization is the difference between "I had to help my uncle Jack off a horse.." and "I had to help my uncle jack off a horse..
Beauty is in the eye of the beer holder
Old 10-01-2004, 12:44 AM
sbono13 sbono13 is offline
Mein Auto: '04 330i ZHP
In addition to the inefficiency of the torque converter, the AT addes about 80 lb to the car's curb weight.
Old 10-01-2004, 03:06 AM
FenPhen's Avatar
FenPhen FenPhen is offline
It's Highly Addictive!
Mein Auto: 2004 330i ZHP
A good drag-race driver has more control in a stick-shift car too, meaning he/she can launch the car more efficiently. The advantage basically comes from being able to control the engine (gas) and the transmission (clutch) independently.
Here's an interesting post that covers launch techniques for an MT car:
http://forums.bimmerforums.com/forum...ad.php?t=47538
2004 330i 6MT · performance package · silver gray · alcantara/cloth · black cube · xenons · pdc · aux audio
Old 10-01-2004, 06:38 AM
Desertnate's Avatar
Desertnate Desertnate is offline
Spelling Impaired
Mein Auto: '10 Mazda3 HB
Something not mentioned also is the shift points.
Unless you have a steptronic tranny or similar where you can make the auto hold a gear, the auto will always shift into the next gear at some point. The next time you need to get on the gas, say coming out of a turn or passing, you have to wait for the auto to react to your input from the gas pedal. With a manual, you can select the gear you want ahead of time, therefor the power is there when you need it, not when the tranny thinks it is needed.
"In the long history of the world, only a few generations have been granted the role of defending freedom in its hour of maximum danger. I do not shrink from the responsibility...I welcome it!" - JFK
Old 10-01-2004, 06:43 AM
ff ff is offline
Mein Auto: people crazy
In addition to what others have said, the gearing is almost always shorter in manual trans cars, when compared to the identical car with an automatic. Shorter gearing should equate to faster acceleration in most cases.
The main thing is control. Control over what gear your car is in at all times. Not such a big deal under normal/lazy acceleration, but a BIG deal when cornering.
Old 10-01-2004, 07:22 AM
hector hector is offline
Mein Auto: '08 128i cpe ac/pw/ps/abs
agree about the efficiency issue but doesn't a torque converter also multiply torque?
Old 10-01-2004, 08:06 AM
norihaga's Avatar
norihaga norihaga is offline
Achtun*, Spitfire!
Mein Auto: '93 E30 318is Touring
Shorter, because you typically have less "gears" to do the same work, so they must be spaced further "apart". And then to get back some of the driveline losses the top gear is usually way overdriven, though I'm basing this on my crappy rental car experiences.
What happens to the gearing if you have the 7-speed Mercedes slushbox? I wonder...
But in any case, you still have the greater %age power loss from the driveline.
Old 10-01-2004, 08:09 AM
///M-Spec ///M-Spec is offline
Mein Auto: '06 Audi S4 25quattro
No. The torque converter simply transmits torque from the engine flywheel to the planetary gearset within the transmission in a smooth, linear fashion. The gears themselves actually multiply torque, just like a gearset within a manual tranny. So to say that an automatic car with a torque convertor multiplies torque implies a manual transmission doesn't also do the same thing. They both do.
Old 10-01-2004, 09:39 AM
Marco Marco is offline
Mein Auto: 325 (2006) - FIAT spider
Absolutely!!!
I hated not being in control when I had an automatic and I am not particularly happy with the StepTr. I have now. Its delay in downshifting drives me crazy.
Fortunately I can have fun with my little FIAT.
MC
Old 10-01-2004, 11:58 AM
st_o_p st_o_p is offline
Mein Auto: '14 535ix
Didn't somebody mention that the auto tranny actually shifts faster than manual cause of the shorter differential?
Old 10-01-2004, 12:07 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
M-Spec, you`d better go back to Auto Trans 101 and brush up on your knowledge....a torque converter MOST DEFINITELY multiplies torque, usually by a factor of between 2 to 3 times. Here`s why a Step (or other auto) feels faster, at least initially....
Let`s take two non-ZHP 330is, one with manual, and one with Step: Torque is identical (214 lb./ft.) for both.
Manual- First gear= 4.35:1 Rear diff= 2.93
Step- First gear=3.45:1 Rear diff= 3.38
If you do the math (214x4.35x2.93), you will see that the manual trans model will give a maximum of 2727 lb./ft of torque (at maximum multiplication). Assuming the torque converter provides a multiplication factor of 2.5, and again, doing the math, (214x2.5x3.45x3.38) you will find that the result is a *staggering* 6238 lb./ft. of torque.
But it`s not all a free lunch....due to fluid & pumping losses there`s a loss of efficiency that eats up some horsepower, and by about 70 mph, the torque converter loses all advantage over it`s stick counterpart.
For proof of this, next time your car is in for service, and they give you the ubiquitous 325i w/Step, try the following (on a deserted road, of course): hold down the DSC button `til the yellow "BRAKE" light comes on....*stomp* the brake pedal with your left foot, and bring the revs up to about 2000 or so, let off the brake, and FLOOR that sumbitch....you`ll swear you`re at Raceway Park....
Regards,
Bob
Old 10-01-2004, 12:13 PM
ff ff is offline
The problem is getting it to shift...
Old 10-01-2004, 03:36 PM
Desertnate's Avatar
Spelling Impaired
By the time it acutally DECIDES to shift and then shifts, you could have shifted a manual and then been on your way.
The lag in the step kills me every time I get a loaner. Furstrating enough I just put it in drive and forget about trying to select my own gears until I am back in my own car.
Old 10-01-2004, 03:55 PM
remington's Avatar
remington remington is offline
Mein Auto: 05 545i
I hate manuals. The average driver would be faster in the steptronic in auto-sport mode than in a manual. Eventually the advantages of a manual BMW will disappear even for skilled drivers as racing technology continues to trickle down to production model auto trannys. Seen a manual F1 lately?
2006 E46 M3
Old 10-01-2004, 04:08 PM
LeucX3 LeucX3 is offline
Send a message via AIM to LeucX3
Mein Auto: 06 VW Jetta GLI
Perhaps, but the fun factor and a sense of control will always warrant a manual tranny for some of us.
Old 10-01-2004, 04:58 PM
jgrgnt's Avatar
jgrgnt jgrgnt is offline
When will then be now?
Mein Auto: 435i GC
2015 435i Gran Coupe
Carbon Black, Coral Red, M Sport Line, M Sport Brakes, 19" Orbit Gray, DHP, Premium, Technology, HK, Enhanced BT, MPPK, MPE, MP rear diffuser, MP black kidneys
Bavsound Stage 1, Bavsound Ghost Subwoofers
Old 10-01-2004, 07:53 PM
shizat63's Avatar
shizat63 shizat63 is offline
takes the long way home..
Mein Auto: 2016 M3
IMHO manual gear boxes create safer drivers that are more alert.
I got a minivan for a loaner at my last service (thanks DiFeo ) and after a few minutes of getting used to not finding a clutch, I tended to zone out and not pay as much attention to the road. I picked up my cell and started jabbing away while I scarfed down a big mac and fries (J/K ) After a few minutes I wondered who stopped at the last couple stop signs.
With a 5 speed you have to look ahead and most of all anticipate- cross walks, hills, merging traffic, other stupid ass drivers that are capable of anything.
But then again I tend to drive faster and more 'spirited' in my 5 speed especially when I aim for that perfect double clutch heel-toe into a corner
Are manual drivers safer?
______________________________
_______________
Old 10-01-2004, 08:24 PM
anon's Avatar
anon anon is offline
**** Yeah
Mein Auto: '04 330Ci
i absolutely agree with shizat63, with a manual you HAVE to be more involved in your driving. with an auto, you just zone out and barely steer.
and if you're gonna get an auto, why bother with a bmw? why not just get an accord for chrissakes?
anon(ymous)
Old 10-02-2004, 03:23 AM
FenPhen's Avatar
The caveat about a torque converter's multiplication effect is that it is only there when the engine is spinning much faster than the transmission (standing on the brake pedal and bringing the revs up close to stall as you describe).
The torque converter can lose its advantage before 70 mph, basically when the transmission speed approaches the engine speed and the stator starts to free-wheel.
Old 10-02-2004, 07:32 AM
[QUOTE=FenPhen]The caveat about a torque converter's multiplication effect is that it is only there when the engine is spinning much faster than the transmission (standing on the brake pedal and bringing the revs up close to stall as you describe).
The torque converter can lose its advantage before 70 mph, basically when the transmission speed approaches the engine speed and the stator starts to free-wheel.[/QU
given what you and fast bob have described, overall in daily driving would you say that one would be experiencing significant torque multiplication or is it reallly just a 1st gear brake-torqueing dragstrip phenomenon?
Old 10-02-2004, 08:09 AM
Moderato's Avatar
Moderato Moderato is offline
VIII
Mein Auto: 07 E92 335i 6MT
Simple, the answer is: Less people you know will ask to drive or borrow your car.
Old 10-02-2004, 08:53 AM
Fast Bob's Avatar
Keeping it surreal
[QUOTE=hector]
In "normal" everyday driving, most converter advantage will be realized with a relatively agressive throttle opening in first & second gear....the higher the RPMs, the more multiplication effect you get. Some American manufacturers give their cars a very agressive (*twitchy*) gas pedal to give the impression that the car is fast.
Regards,
Bob
  #25
Old 10-02-2004, 09:12 AM
jsc's Avatar
jsc jsc is offline
Mein Auto: E85 M-Roadster, E82 135i
Basically at low revs you will get a torque multiplication effect similar to a lower gear until the fluid stops shearing between the rotor and stator, this gives the "disconnected" feeling of an automatic transmission, it has two side-effects - a continuously variable gear ratio within a small range and a buffering effect that cushions the driveline. Once the stator and rotor spin at the same speed, there is no torque multiplication.
Really the torque multiplication of the torque converter has limited practical use, if you try to use this effect for increasing the vehicle performance you can easily overheat the transmission (torque braking for more than a couple of seconds can easily do this as you are dissipating the engine power by shearing the transmission fluid and converting most of the power into heat).
Similar Threads
Manual climate control retrofit...(the saga continues) bmw325 3 Series & 4 Series 14 12-30-2004 03:24 PM
Are you an Manual or Automatic buyer ? mark1 3 Series & 4 Series 130 10-08-2004 12:08 AM
323/325 328/330 etc. engine changes Optimus Prime General BMW Questions 15 04-03-2004 07:56 PM
SMG Steptronic Automatic Manual question drbmw General BMW Questions 29 03-28-2004 05:24 AM
Manual vs. Automatic - Various Choices Ack General BMW Questions 27 07-18-2002 07:22 AM
