Old 11-21-2013, 01:18 AM
casey90 casey90 is offline
Mein Auto: e92 335i
e92 335i alarm issue?
hello,
i'm having this problem for like 2 months now, the car is 335i 2010 has only 31000KM on it (19375 miles).
and this problem appears,
when i try to unlock the car with keyfob the alarm will go off for about 15 seconds then the car will be dead electronically, like no light no seat adjusment, even the car key wont lock in its place when i try to insert it.
then after like 1 hour the electricity is back to the car and then its 50% 50% if its gonna work or do the same again if i try to unlock it.
i took it to the dealer and they replaced the whole alarm siren in the car, afterwards car runs with no issue for about 3 weeks and now its back again.
anybody heard or had this issue before?
Old 11-21-2013, 06:00 AM
Nerdboss Nerdboss is offline
Mein Auto: 2011 328i
Originally Posted by casey90 View Post
hello,
Sounds like a bad battery?
Old 11-21-2013, 07:00 AM
Mein Auto: e92 335i
not at all,
100% battery is not the problem. the alarm somehow is locking down the car.
Old 11-21-2013, 07:51 AM
Mein Auto: '06 AW 330xi
I would start by unplugging the alarm modules. The ultrasonic sensor in the overhead done light, the siren in the rear driver's side wheel well, and the hood sensor on the driver's side microfilter housing.
If the issues persist, it's not your alarm.
Something is hanging and drawing current when you turn off your car. You need to start pull fuses and parts to see where the draw is.
Old 11-21-2013, 11:36 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
not at all,
How do you know?
Old 11-21-2013, 01:03 PM
Mein Auto: e92 335i
Originally Posted by CALWATERBOY View Post
How do you know?
because when it happened the first time i had it towed to the dealership and they said the battery is fine nothing wrong with it (the car is only 3 years old) then they found an error code which they never experienced before in other beemers.
they replaced the whole alarm siren part in the car because it showed that there was a problem with it but the problem still in the car
Old 11-21-2013, 05:10 PM
Ummmmmm. View video; try that backyard bumpkin evaluation....
Cold over there?
Old 11-02-2015, 06:02 AM
Kev621 Kev621 is offline
Send a message via ICQ to Kev621
Mein Auto: BMW 325 Ci
hello,
Hi!
This is a long shot bit i have to try!
I have the exact same problem and can't find the problem.
Does anyone know what the problem could be?
