Old 11-21-2013, 04:38 AM
meatsword meatsword is offline
Mein Auto: BMW E65 745i
Help with some error codes
Hi all,
I really hope someone can help me out with my problem
I will tell you all the symptons of my problems, but first here are the error codes the hidden dash shows up:
0931C,
1A3BA,
2A3BA,
3A3AE,
4A548,
5931B,
69319,
7931D,
8E111,
9E104,
AE107.
Now here is the problems I am having with the car:
1. If I sit in the car with the engine off, the car with say recharge battery in less than 2 minutes, this is done with iDrive off, lights off, heating off,
2. The hidden dash shows voltage with engine on as 14.5V, when engine is off this drops to 12.8V and in less than 2 minutes this will drop to 12.2V and the recharge battery warning displays,
3. When driving if I turn on the heating up to 32.0 degrees celcius and fans upto full sometimes they come on the the fury of an angry god but sometimes not at all, similarly if they are on they will suddenly dip in power for a few seconds then come on again,
4. If I am driving listening to the FM radio sometimes a loud click comes through the speakers and the volume drops to nothing then comes back again a second later at a lower volume than it was before the click. This does not happen with CDs from the centre of dash or multichanger,
5. When starting cold the car will idle perfectly but have a very slight shake at around 1,000 rpm - 1,500 rpm. However if I hit the accelerator and take the revs up to 3,000 rpm then let them drop the shake disappears. Also if it shakes and I turn the car off and on again it also disappears.
6. Sometimes when starting cold in the morning and trying to select reverse I get "transmission failsafe" and reverse gear is not selectable, however if I turn the car off and on again the problem is fixed,
7. When driving at speed on motorway when I use the cruise control the car will cruise just fine but randomly the car will gently lurch and the revs will jump up 500 - 1,000 rpm but immediately go down again. This happens randomly whether it is in D or M regardless of whether it is going uphill, downhill or on flat. It also does not change gear when it does this and will happen in any gear number, it is completely random,
8. There is a driver restraint warning message,
9. There is an engine check light on the dash but no further warning or limp mode at all,
10. The power boot (trunk) does not open on its own unless I push the button and help it for the first inch manually then the automatic system lifts it the rest of the way. Similarly it will not close when pushed on the fob but will close itself if I press the button on the inside of the lid.
I am really sorry for the length of this post, I really hope you can give me some pointers because I have no idea what is wrong. I have read many different posts and some things could point to the battery being the route cause, then again it could be battery, transmission and ignition.
I am waiting till the end of the month then buying a new battery and programming it in with INPA. I am going to try reprogramming the current battery incase the previous owner had replaced it unaware that it had to be programmed in and see if this makes a difference.
After that would changing the battery, crankcase vent valves, integrated supply module, all eight spark plugs and ignition coils and replacing the transmission fluid, sump/filter/seal and mechatronics sleeve do anything to help? All are cheap enough to do and easy enough for me to do but I would rather not spend money unless required.
Please can someone help me out? I would really appreciate any help on solving my problem.
Many thanks in advance!
P.S. My cable for INPA will come around Friday/ Saturday so I can give further information on codes, etc then.
Old 11-21-2013, 05:28 AM
Nygel's Avatar
Nygel Nygel is offline
Mein Auto: BMW 750Li
There is a "Stickie Thread" with a list of all the codes binary and definitions, please do a search you will find.
Old 11-21-2013, 06:02 AM
All I found searching was this thread:
http://www.bimmerfest.com/forums/sho...d.php?t=683744
and both documents posted do not reference any of those codes at all
EDIT: I also found a document in another thread that was 338 pages long, but none of the error codes I have matched that. Could someone help me out with either the correct search term or link to the sticky?
Thanks again
Last edited by meatsword; 11-21-2013 at 06:15 AM. Reason: Adding more information.
Old 11-21-2013, 07:14 AM
SuperSnoop's Avatar
SuperSnoop SuperSnoop is offline
Mein Auto: 2007 760Li
First, get the codes cleared and see what comes back. There's no point in chasing down one-time glitches.
Second, how old is your battery? It sounds like your battery is getting weak. A new one will need to be coded to the car.
Third, you can get the check engine light error scanned at any auto parts store. It's an emissions related fault that could be a bad gas cap or something much worse.
Finally, I'm counting about seven different issues in your message. It's probably best to tackle them one by one. You should probably start with telling us what type of car you have.
Old 11-21-2013, 07:41 AM
I have no idea how old the battery is, I asked the previous owner and he said he didn't replace the battery while he had it but he only had it a few years so the previous owner to him may have.
The car is a 2002 745i (E65) UK model. It is at 90,200 miles on the clock and has had a full BMW main dealer service history and services done at approx 8,000 mile intervals.
I bought it almost two months ago and the problems have only just started in the last 2 weeks, which is why I thought of battery as the ambient air temperature is now much lower.
I will have the codes cleared asap and report back.
Thank you for helping thus far really appreciate anyones input and time.
Old 11-22-2013, 07:28 AM
Update
OK guys so I got some more information.
I got the following codes read last night (the reader found 94 faults)
iPhone Fault Report - BMWhat - 6.00 - 6.00 FV
ID1: C4500B8E-4B20-4CC9-8FC5-110E130A2AC6-6445-000005EF02618484-aad
ID2: 72EF09F0-92D6-4C57-AEBA-F7F19A4DDE66-6445-000005EF0261884C-1202
INFO: >0B09C9B8A7A4917A63524E35281C6<
2013-11-21 19:03:42
BASE-MODEL: E65
SELECTED-MODEL: 745 i,Li N 62 B 44
FAULTS: 94
ECUs: 46
BATTERY: 14.6V
DEPTH: Normal communication
SPEED: normal
CONNECT: Normal connection
VERSION: 6.1.3
DEVICE: >Ryan's iPad< >iPhone OS<
WIFI: >WiFi_OBDii<
ELM: >ELM327 v1.5<
COM+: >UNKNOWN<
0. Motor Control:
Engine / Motor:
- Fault: :Electric fan motor activation / Power management battery quiescent current of injury / e-fan
- Code: BMW 279D
- Fault: :Secondar air system / Secondary air-injection system / VANOS maximum support socket bank 1
- Code: BMW 2760
- Fault: :Secondar air system / Secondary air system / Stop the maximum inlet VANOS Bank 2
- Code: BMW 2761
- Fault: :Secondary air valve mechanism / Communication error generator
- Code: BMW 279B
- Fault: :Multipl adaptation. area1 / Mixture adaptation, deviation / Lambda-probe electrical diagnostics nkat Bank 1 / LR adaption fault / Multiplicative adaptation area1
- Code: BMW 272A
- Fault: :Adaption additive per time (Bank2) / LR-Adaption add. per time (Bank2) / Lambda probe heating driver diagnostic nkat Bank 2 / LR adaption fault
- Code: BMW 272D
1. ABS / DSC / Brake:
Active Roll Stabilization / Rollstabilisierung:
- Fault: Proportional valve HA / Proportional valve rear
- Code: BMW 5D4F
- Fault: Oil level sensor / Thermo-oil sensor
- Code: BMW 5D60
- Fault: internal
- Code: BMW 5D62
- Fault: Throttle actuator control circuit bank 1 review
- Code: BMW 5D66
- Fault: Vehicle lateral acceleration DSC CAN / CAN Vehicle acceleration Cross DSC
- Code: BMW D1DD
- Fault: DSC yaw rate CAN / CAN DSC yaw rate
- Code: BMW D1DE
- Fault: Outside temperature CAN / CAN Outside temperature
- Code: BMW D1E0
- Fault: Steering wheel angle CAN / CAN Angle of the steering wheel
- Code: BMW D1E4
- Fault: Speed of the motor CAN / CAN Engine Engine
- Code: BMW D1E5
- Fault: Steering wheel angle gradient CAN / CAN gradient angle of the steering wheel
- Code: BMW D1E8
Dynamische Stabilitaets Kontrolle / DSC:
- ECU not present/no answer
Hand brake / Feststellbremse (EMF):
- Fault: unkown failure
- Code: BMW 6025
- Code: BMW 6032
- Fault: CAN signal not plausible
- Code: BMW D3BD
- Code: BMW D3BE
- Fault: communication fault ABS ESP / unkown failure
- Code: BMW 6040
- Fault: communication fault ABS ESP / Terminal shutdown
- Code: BMW 6044
2. Airbag:
Satellite A-pillar left / A-Saeule links:
- ECU OK, no fault code
Satellite A-pillar right / A-Saeule rechts:
Satellite front left door / Tuer vorne links:
Satellite front right door / Tuer vorne rechts:
Satellite driver seat / Fahrersitz:
- Fault: Interruption SBE1
- Code: BMW 9763
Satellite front passenger / Beifahrersitz:
Satellite B-pillar left / B-Saeule links:
Satellite B-pillar right / B-Saeule rechts:
Satellite backseat / Ruecksitz:
Satellite center / Mitte:
3. Transmission Control:
Transmission / Getriebe GS 19:
- Fault: monitoring gear
- Code: BMW 4F4C
- Fault: Parking brake failure
- Code: BMW 507C
- Code: BMW 507B
- Fault: gear control
- Code: BMW 4F4D
- Code: BMW 4F4B
4. Instrumentation:
Instrument cluster / Kombiinstrument:
- Fault: short circuit display heater / Short-circuit display heater
- Code: BMW 931C
- Fault: CAN ID failure
- Code: BMW A3BA
- Fault: CAN signal fault immobilizer
- Code: BMW A3AC
- Fault: CAN ID failure / CAN signal fault engine idle
- Code: BMW A3AE
- Code: BMW A548
- Fault: Outside temperature is too low - K-LIN 5.7 sunshade driver / passenger rear / Outside temperature sensor
- Code: BMW 931B
- Fault: level actuator / Tank level error
- Code: BMW 9319
- Fault: supply voltage failure
- Code: BMW 931D
- Fault: Long and / or frequent Unlocks
- Code: BMW E111
- Fault: CAN LOW ERROR
- Code: BMW E104
- Fault: K-Can Bus off
- Code: BMW E107
Center-Konsole:
- Fault: Bus Error / CAN-Low, physical bus error
- Code: BMW E244
Center-Konsole:
Central info display / Zentrales Display:
5. Light/Rain Control:
Light / Licht:
Rain/light sensor / Regen-Lichtsensor RLS:
- Fault: sorry, unknown DTC fault
- Code: BMW DA44
Wiper / Scheibenwischer:
- Fault: K-CAN SYS low/HIGH Fehler
- Code: BMW DA84
Light / Licht:
- Fault: Short circuit fault 4
- Code: BMW 9CB6
- Fault: unknown failure
- Code: BMW E504
High-beam / Fernlichtassistent:
6. Heating / AC:
Air conditioning / Klimaanlage:
- Fault: Short circuit to positive or open circuit - additional water pump
- Code: BMW 9C76
Rear Air conditioning / Klimaanlage hinten:
Additional heater / Zusatzheizung:
7. Immobilizer System:
CAS:
- Fault: CAS Supply Error
- Code: BMW A0B2
- Fault: Central control timeout
- Code: BMW D904
8. Park distance control / PDC:
Park Distance Control / PDC:
- Fault: Function Display
- Code: BMW 9E29
- Fault: Switch
- Code: BMW 9E2A
- Fault: HR-CT errors / Transformer fault HR
- Code: BMW 9E2C
- Fault: VML converter error
- Code: BMW 9E31
- Fault: Inverter VL / Transformer lines VL
- Code: BMW 9E37
- Fault: Inverter Board / Converter cable VR
- Code: BMW 9E38
- Fault: Inverter VML / VML converter cable
- Code: BMW 9E39
- Fault: Inverter VMR / Converter cable VMR
- Code: BMW 9E3A
- Fault: CAN-Low, physical bus error
- Code: BMW E204
9. Cruise Control:
Active cruise control / Aktive Geschwindigkeitsregelung:
10. Sunroof / Roof:
Sunroof / Schiebedach:
11. Audio / Navigation / Communication:
Multimedia-Changer / Wechsler:
Speech recognition / Spracherkennungs-system:
Phone / Telefon:
- Fault: Long and / or frequent Unlocks / too many or too long unlocks
- Code: BMW D691
- Fault: Awakening device has tried three times unsuccessfully to wake up network
- Code: BMW D68D
Hifi Amplifier / Verstaerker:
- Code: BMW D6D1
- Fault: DSP error / No communication / ECU overtemperature / Internal controller fault
- Code: BMW A1A8
Tuner Antenna / Antenne:
Hybrid Radio USA:
Digital Satellite-Tuner USA:
Central Control Fond:
Headphones / Kopfhoerer Schnittstelle:
Navigation:
CD-Changer / Wechsler:
- Code: BMW D811
- Code: BMW 9D28
- Fault: CD changer error unload mechanism
- Code: BMW 9D29
Audio-System:
- Fault: Message failure
- Code: BMW D8CE
- Code: BMW D8D1
- Code: BMW D8CF
Video:
- Fault: ring diagnostic check error
- Code: BMW DBD0
- Fault: too many or too long unlocks
- Code: BMW DBD1
DAB:
12. Seats:
Seats / Sitze:
Seats / Sitze:
Seats / Sitze:
Seats / Sitze:
13. Systems:
Gateway:
Steering column switch / Lenkstockschalter:
- Fault: LWS fault
- Code: BMW 94E7
Tire pressure control / Reifendruck Kontrolle:
Passive Go System:
Boardcomputer / MMI:
Chassis Integration CIM:
- Code: BMW 5D2C
- Fault: internal
- Code: BMW 5D2D
- Fault: MLSL-
- Code: BMW 5D30
- Fault: MLSN +
- Code: BMW 5D31
- Fault: Hall sensor
- Code: BMW 5D36
- Fault: Position data
- Code: BMW 5D38
- Fault: Bus Error
- Code: BMW D984
Power Module:
- Fault: Error tailgate Contact
- Code: BMW A156
- Fault: Discharge error
- Code: BMW A15D
Night Vision:
Flexible Bus-Interface / Schnittstelle:
MOST / CAN:
- Fault: Bus Error / Line fault detection K-CAN
- Code: BMW E184
- Code: BMW E191
- Fault: unknown failure / Message failure
- Code: BMW E18D
MMI:
Night Vision Camera:
14. Anti-theft alarm system:
Security / Sicherheitsmodul:
- Fault: No communication with phone
- Code: BMW 9487
- Fault: Undervoltage detected / Satellite B passenger side pillar X / MRSA-B X right / Left pillar Y-direction
- Code: BMW 93DF
- Fault: Stack Overflow / Co-driver
- Code: BMW 93C1
Interior protection / Innenraumschutz:
Theft alarm / Diebstahl Warnanlage:
15. Chassis:
Air suspension / Luftfederung:
Electronic damper / Elektronische Daempfer:
Ergo-Commander:
- Fault: CAN physical error error / Bus low error rate
- Code: BMW E2C4
16. Body:
Trailer / Anhaenger:
Door / Tuer:
- Fault: Faulty sensor
- Code: BMW 9B57
- Fault: interruptions
- Code: BMW 9B4A
- Fault: Invalid window position
- Code: BMW 9B66
Passenger door / Beifahrertuer:
- Code: BMW 9B8A
- Fault: Defective transistor bridge
- Code: BMW 9BA4
- Code: BMW 9BA6
Rear driver door / Hinten Fahrertuer:
- Code: BMW 9BCA
Rear passenger door / Hintere Beifahrertuer:
- Code: BMW 9C0A
- Fault: CAN low fault
- Code: BMW DCC4
Tailgate / Hecktuer:
17. Other:
Old 11-22-2013, 07:30 AM
more information
Apologies for multiple posts in a row but I thought it better to split these instead of having one mega post.
I then cleared the codes above and drove the car around (already warmed up) for around 30 miles trying to get up and down gears, park, reverse, hard accelerate, etc.
Here are the fault codes after this:
ID1: CD64529D-74CF-48A9-BD7B-4974D4B882A6-6445-000005FE1010C87F-a7c
ID2: BEFF40CF-F1AE-4102-A1FD-647FDCC97805-6445-000005FE1010CC40-124a
INFO: >0700D8C7B6B3A08972615D44372B6<
2013-11-21 19:48:36
BASE-MODEL: E65
FAULTS: 4
ECUs: 46
BATTERY: 14.1V
SPEED: normal
VERSION: 6.1.3
WIFI: >WiFi_OBDii<
ELM: >ELM327 v1.5<
COM+: >UNKNOWN<
0. Motor Control:
Engine / Motor:
- Code: BMW 279D
- Code: BMW D1E4
2. Airbag:
4. Instrumentation:
Center-Konsole:
- Code: BMW E244
Center-Konsole:
Light / Licht:
Light / Licht:
6. Heating / AC:
CAS:
- Code: BMW E204
9. Cruise Control:
10. Sunroof / Roof:
Phone / Telefon:
Hybrid Radio USA:
Navigation:
Audio-System:
Video:
DAB:
12. Seats:
Seats / Sitze:
Seats / Sitze:
Seats / Sitze:
Seats / Sitze:
13. Systems:
Gateway:
Passive Go System:
Power Module:
Night Vision:
MOST / CAN:
MMI:
15. Chassis:
Ergo-Commander:
16. Body:
Door / Tuer:
17. Other:
Old 11-22-2013, 08:43 AM
Nygel's Avatar
Re: Help with some error codes
Replace your battery, get it registered and then clear all trouble codes.
Sent from my HTCONE using BimmerApp mobile app
Old 11-22-2013, 08:51 AM
I get INPA EDIABAS tomorrow so I am going to try and register the current battery to the car and drive it around and get the voltage drop when engine is off and power on. If the drop is not bad then will I still need to replace the battery, or is it advisable to simply replace the battery anyway?
Also thanks again for your help and input. I have more fault codes from this morning, it was left in the -5 degrees night all night and was cold this morning, I drove it into work and got some VANOS fault codes again along with the e-fan, but when I cleared the codes only the e-fan code was still around. I was going to post the results but my iphone isn't letting me take the text file attachments of the report.
Old 11-22-2013, 08:59 AM
Nygel's Avatar
If it's a new battery then re-register it. If it's the original then replace. Your car will still think you have the orginal battery when the voltage spikes and drop start happening.
Old 11-22-2013, 03:42 PM
Pauls79 Pauls79 is offline
Mein Auto: 2002 745i, Clio 172
Hi, I would recommend you fit and code a new battery. I had lots of silly faults and ended up putting a new AGM battery on and getting it coded. Solved most faults. I no the DSC fault stayed on but the steering angle sensor required setting as it lost its memory due to the bad battery. As for the faulty boot, mine required the oil topping up for the hydraulic ram and both gas struts changing.
