Old 11-21-2013, 07:16 PM
11335xi 11335xi is offline
Mein Auto: 2011 BMW 335xi M-Sport
2011 335xi not starting
The car is a 2011 with 12k miles and has not been started for about a month. I'm pretty certain the battery is dead. I tried jumpstarting it from the engine compartment. All the electronics come on, but when I press the "start" button with my foot on the break, it seems to make a short crank and gives up. I tried jump starting through the battery and had the same issue.
Any help would be appreciated.
Old 11-21-2013, 07:44 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Oh ye of but one post.....how little thou knowest.
Viewth THIS VIDEO and thou shalt know wherefore thou art.
Old 11-21-2013, 08:06 PM
I've been here just reading for a while, never needed to post until now.
So does that mean I should get a new battery? I'm not entirely sure what was being said there.
Old 11-21-2013, 08:32 PM
Mein Auto: '06 AW 330xi
If your car was built before 7/11, did you have the battery cable recall done?
Old 11-21-2013, 08:41 PM
Well here's the thing. I actually just got the car today. I got it out of the auction (it had been crashed, repaired, and sold by insurance company). About a month ago, it started no problem. But since then it has not been started. It sat in storage for 2 weeks before delivery driver picked it up (it was lifted by forklift, no attempt to start it was made).
I decided to come here before going and spending money to have it repaired. It's clear to me the battery is dead because absolutely nothing electronic works until I attach a jumper cable/trickle charger, but even then, it only makes a short crank, stops, and seems the electronic components reset.
Shouldn't it be able to be jump started? I know the battery is dead but it only has 12k miles on it so I'm not sure if it's DONE dead, or just "light left on a long time" dead.
I was also told (and I'm not sure if it's true) that the battery has to be fully charged in order to start the car.
Old 11-21-2013, 09:09 PM
elpina11 elpina11 is offline
Mein Auto: 06 530i
The battery has to be fully charged then tested to determine if its a bad battery. A discharged battery doesn't mean failed battery.
Old 11-21-2013, 10:06 PM
Did you view the video? Charge the battery - then run the test.
Old 11-21-2013, 11:28 PM
Yeah I saw the video and I'll do that first thing tomorrow after work. Thank you!
Old 11-21-2013, 11:29 PM
I will try that tomorrow. Thank you!
Old 11-22-2013, 12:59 AM
Hey post the result - other'n video are links for DIY battery R&R and DIY battery registration, which you MUST do regardless of whether or not you replace with identical unit....
