Old 11-22-2013, 03:01 AM
Charge Charge is offline
Mein Auto: E90
Having fog inside only 1 headlight after washing?
I have aftermarket headlights that were installed couple of days ago, yesterday i went to wash my car, i only washed it with a hose to get some dirt of it.
the temperature outside is fine ~25C and there was no rain or anything.
i also washed both headlights from the outside and then after i finished i noticed that one of them became foggy inside, i dident know why it happened but i left it out so maybe it will disappear but today i came after almost 24 hours and still one headlight has fog inside it and the other one clear as crystal.
can anyone help me? is there anything wrong with my headlight? thanks!
Old 11-22-2013, 06:48 AM
bocabimmer's Avatar
bocabimmer bocabimmer is offline
Found the Search Button
Mein Auto: 2007 E92 328i, 2014 i3
There is a leak somewhere. Simplest place to check is the access ports for the light bulbs. If not there, you may want to buy some silicone sealant and seal between the lens and housing.
Which brand are those?
2014 i3 BEV
2007 328i (E92) - BMW Performance exhaust, short shift kit, handbrake and steering wheel trim - CDV delete - CREE LED corona rings - LED license plate lights
2006 325i (E90) - SOLD - projector headlights, blackline taillights - satin grilles - shadowline trim - style 338 wheels
2000 ML430 - SOLD - heavily modded, I miss that truck
Old 11-22-2013, 06:57 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Uhhhhhhhhhhh.......YES
That's not normal, as I believe you've guessed.
Help you to do what? Clear the fog? Seal the unit? Complain to the manufacturer + make a warranty claim?
A good example -- when using aftermarket parts -- it's caveat emptor.
Old 11-22-2013, 07:51 AM
Mein Auto: E90
damn, update: "what i did was to remove the high beam bulb and fan it from the inside, it made it disappear."
two hours later: WTH, after i finushed all the drying i closed everything up, the car just sat in the garage, i dident started it up nor there was any rain or cold temps but when i came a hour later again there was condisation inside the same headlight.
so what are my options now? what should i do? where to start checking?
thanks!
Old 11-22-2013, 07:56 AM
bocabimmer's Avatar
You have a garage... Leave the headlight open overnight and let it air out.
2014 i3 BEV
Old 11-22-2013, 08:20 AM
Mein Auto: E90
do you mean open the hood? the bulb covers? take the bulbs out? what to open?
Old 11-22-2013, 10:25 AM
HPIA4v2 HPIA4v2 is offline
Mein Auto: E60, E71, E92
That looks bad, overtime it will stain the inside lens, hase the plastic optics etc
I have original headlamp like that, will ask dealer to replace it since I am still under waranty and only on passenger side.
Old 11-22-2013, 10:42 AM
Mein Auto: E90
Well i dont think it is that drastic, there must be a solution to this maybe a seal to the back cover, meanwhile the manufacturer claims it is somethong that will happen for 1 or 2 times then will disappear and will not happen again, we will how thinga unfold, i will update
Anyways if anyone got solutions he think might work i will be happy to hear them.
Old 11-22-2013, 10:46 AM
Which manufacturer is that?
Old 11-22-2013, 11:07 AM
bocabimmer's Avatar
You could seal the headlight yourself, but then again you may be better off trying to get one that doesn't leak to begin with.
The seller's response sounds like a way to delay you sending it back until after the traditional return period has ended.
Who is the seller? Those of us who are close to buying lights want to know.
2014 i3 BEV
Old 11-22-2013, 11:16 AM
Mein Auto: E90
ATM i do not want to hurt the reputation of any manufacturer, i will see how this issue is going on and i will update.
Old 11-23-2013, 04:40 AM
Banned
Mein Auto: 2007-335 HTC
I would send it back immediately, if it leak now it will always leak, if you dont send it back now the next post will be,
Manufacturer wont take defective light back
Old 11-23-2013, 06:27 AM
Do you have psychiatric issues?
Are you taking medication?
MANUFACTURER SCREWED YOU! Notified of malfunctioning product, they opted to BS: YOU
Old 11-23-2013, 02:43 PM
Mein Auto: E90
Well i managed to detect at least one place that has a broken seal and water coming in from, did notified the manufacturer, waiting for his response.
promise to keep you updated, btw for those wondering, no psychiatric issues nor medications taken
Old 11-24-2013, 05:09 AM
Mein Auto: '06 AW 330xi
These headlights are NOT 100% sealed. There are pressure vents on the top and bottom of the headlights.
There shouldn't be that much condensation but a little is possible. Don't go crazy trying to get an air tight seal, it won't and should not be 100% sealed.
Check the turn signal socket.
Old 11-24-2013, 06:04 AM
Cooms Cooms is offline
Mein Auto: 335XI
I had the same thing happen time, however my fault. I upgraded my HID bulbs and didn't seal the access door all the way. Come to find out it cracked and the notch where it clipped in broke. Ordered a new cover from ECS tuning, all good now.
BTW to remove the condensation, let car sit in hot sun or blow compressed air into the turn signal bulb access hole
Old 11-24-2013, 11:08 AM
E92-Lighting's Avatar
Mein Auto: 335i
big time, this isnt a joke
BMW ACCESSORIES and PARTS
