E36 (1991 - 1999)
Old 11-22-2013, 02:11 PM
pj3 pj3 is offline
Mein Auto: 530xi, 328is, 911TT, 325i
ABS/ASC light on, 1999 328is
This is real head scratcher.
I have a last month of production 328is E36 (99/3). The ABS/ASC started to misbehave. The lights come on as soon as I start turning right when driving. I replaced all ABS sensors (they looked like they needed it) but the problem did not go away.
The next item on the troubleshooting list is a brake position sensor, should be mounted on the booster. Realoem shows it when I punch in my VIN (ET08584), however it is nowhere to be found in the car. The only two openings on the brake booster are for the vacuum hose and the master cylinder. (The brake booster I have in the car is 34331163561).
This car is using a standard ABS module behind the glove box, sitting on the L-Line. This module must be getting the brake position from somewhere. What am I missing?
BTW, I cannot test L-line modules, DIS doesn't see them so I am going in blind...
Any ideas?
Old 11-22-2013, 03:53 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
You're not confusing the wheel speed sensor for the brake pad sensor, are you? Anyway, usually it's a bad wheel speed sensor or a bad ABS unit. Have you scanned the car?
1998 BMW 328is
1966 Pontiac GTO
Old 11-22-2013, 04:56 PM
pj3 pj3 is offline
I replaced all of the wheel speed sensors. (No I am not confusing the with pad wear sensors).
I cannot read the ABS module, it is sitting on the L-Line, none of the scanning equipment I currently have does L-Line. (Carsoft will, I hope, getting it in a few weeks)
I just don't understand why my car doesn't have the brake pedal positioning sensor. Where is the ABS module getting info about brake position readings from?
Old 11-22-2013, 07:37 PM
SPapaJr's Avatar
SPapaJr SPapaJr is offline
VP Moon-Based Operations
Mein Auto: 1998 323is
Does it come on if you just let it sit there and idle?
When I was chasing down my ASC problem (which had to do with the TPS) It would eventually come on during idle. Are the screws that hold down the TPS and ASC throttle body sensor tightened down? Some times they can eventually come loose through years of vibrations from the engine.
Old 11-22-2013, 07:58 PM
pj3 pj3 is offline
Interestingly enough, I have also replaced the throttle positioning and ACS sensors on the throttle body. This was to cure erratic idle. The DME was complaining about the throttle body sensors. The idle is perfect now.
What I need to figure out is how come my car doesn't have the brake pedal sensor.
Old 11-22-2013, 08:06 PM
SPapaJr's Avatar
You know what don't worry about it ( mine doesn't have on either, but that's besides the point). I had a feeling about you messing with the throttle sensors, because I did the same.
I never found a concrete solution, but what I ended up doing was clearing all codes I could from my car then starting it up and letting it idle for 8-10 minutes; don't touch the gas pedal at all. Just let it idle then shut it off. I did this and my ASC has yet to come back on.
This is just a guess, but I think that the car has to relearn adaptation values for the TPS. I believe the new sensor maybe giving off a reading that the DME is not used to so it thinks something is wrong and throws the ASC off. Again, I'm just assuming, but I haven't had problems with it for a while, now.
Old 12-07-2013, 09:13 AM
pj3 pj3 is offline
I might be getting somewhere, just don't know where yet..
An ebay version of a Carsoft package (6.5, all HW, an install CD) arrived in the mail last Thursday. After installing on my old X60 (with a proper serial port in its base) I was able to communicate with a couple of modules, however the ABS/ASC was nowhere to be found.
After a lot of reading, I have opened the 20 pin connector on the cable that came in the carsoft package, moved a wire originally connected to pin 17 to pin 15 (while removing the pin 15 one). Once this mode was done I could see the ABS module, which was reporting the following errors (translated from German):
50 - Throttle valve mechanical fault
130 - Throttle positioning potentiometer
As I mentioned before, I have replaced pots on both throttle's (one connected to the actual throttle, one operated by the ASC system)
No check engine light, no idle issues since the replacement.
Is there an adaptation I need to do on the ASC throttle? I cannot find any information about this.
One important thing to mention. When no ABS/ASC lights are on, the system works well. Tested over a couple of days driving in 5" of snow.
Unfortunately, the ABS/ASC lights come on after a while resulting in no ABS/ASC.
Old 12-07-2013, 01:25 PM
pj3 pj3 is offline
After erasing the ABS/ASC errors, I drove the car all afternoon. So far so good.
Old 12-07-2013, 11:01 PM
SPapaJr's Avatar
Yes these were the same codes I had and after clearing them they would come back on after a week or so of driving.
I originally read about the "idle for 10 min" from a thread about CAIs. Basically, it said to do this to allow the DME to adjust to the new airflow etc. TPSs regulate airflow, so I decided to try it out to get rid of my ASC light. At least it made sense to me and it worked.
Maybe it was a fluke, but since it only took 10 min of my time, it really couldn't hurt.
abs/asc
