Old 11-24-2013, 10:51 AM
BimmerLM BimmerLM is offline
Mein Auto: 07 335i
335i HPFP Question
First time poster here, just lookingf or advice. Here's the situation.
07 335i 78k miles
Brake and dsc lights came on 2 weeks ago intermittently.
Engine malfunction message two days ago.
Rough idle when cold (fist start of the day) but then seems fine.
Took it in to a euro shop and they did diagnostic and came up with a bad throttle body. Also warned me that the brake and dsc light usually light up during this problem but there could be a chance that after the TB install, the brake and dsc could be in fact be a seperate issue but couldn't know until after TB install.
I reluctantly gave the nod for the $986 throttle body replacement.
Engine now idles fine and now no engine malfunction message, but after repair, brake and dsc lights still on. They let me know it would be approx 2k for a abs hydronic pump unit.
My question ... Is it safe to drive with this issue?
Thanks sorry for the novel.
Old 11-24-2013, 12:32 PM
floydarogers's Avatar
Pedant and Curmudgeon
Originally Posted by BimmerLM View Post
...Engine now idles fine and now no engine malfunction message, but after repair, brake and dsc lights still on. They let me know it would be approx 2k for a abs hydronic pump unit.
You may be able to have the control module rebuilt for a significant cheaper repair; search around for the subject of ABS control module.
It's safe, if you remember you don't have ABS or DSC. Brakes should work fine.
I think you mean "hydraulic" rather than hydronic.
Old 11-24-2013, 02:06 PM
Mein Auto: 07 335i
Thanks for the insight...
Yes I did mean hydraulic pump.
Also tried to change title of post from HPFP to something better but couldn't seem to change it.
Anyway, thank you for your reply. I'll google around.
Old 11-24-2013, 04:27 PM
Ilovemycar Ilovemycar is offline
wooohooo
Mein Auto: '08 335i coupe 6MT sport
I am NOT an expert, but if the car seems to run fine with simply a rougher idle when cold right at the first start of the day... I'd be curious if it was simply your battery saying "replace me". Are you on original battery? For the idle, again not an expert here, but maybe it could be the coking of your intake valves, google "walnut shell blasting" for more info, many here have had that done, and it will be in my perhaps relatively near future.
Other than that, Floyd knows 100x more than I do about cars.
Old 11-24-2013, 05:10 PM
Mein Auto: 07 335i
The battery is about a year old.
As stated, that issue is good now (after throttle body replacement).
My main concerns now are 3 lights on the dash...and a cramp in my leg with no cruise control.
Main reason for posting to the forum is to
A) see if it was safe (mechanically) to drive with the Brake,dsc, lights on -and wouldn't cause more damage.
and B) see if there were any folks who had the same experience and a better alternative to a 2k replacement regarding the hydraulic pump.
Thanks to all!
