Old 11-24-2013, 10:05 AM
rumblin70ss rumblin70ss is offline
Mein Auto: 335XI
2008 335xi......Slight Hesitation Upon Acceleration?
Hey there everyone,
First time BMW owner and I have a question. When I start to accelerate, the car seems to hesitate very slightly, almost like I need to give it more gas pedal than I'm used to. It does it hot or cold and it starts/idles/runs fine, never missing a beat. Is this just one of the quirks of this car? If it's an issue I'd like to get it worked out before the warranty runs out in a few months.
Any help is appreciated!
Tony
Old 11-24-2013, 10:16 AM
Nerdboss Nerdboss is offline
Mein Auto: 2011 328i
Originally Posted by rumblin70ss View Post
Hey there everyone,
Tony
How many miles? May need to have the intake valves cleaned with a walnut shell blasting.
Old 11-24-2013, 11:26 AM
floydarogers's Avatar
Pedant and Curmudgeon
It's almost certainly the fact that the car starts in 2nd gear (if you have an automatic) and it takes a bit of rpms to build up boost for the turbos. Try starting in sport mode/1st gear. You can/should also search here for similar experiences before posting - this is quite a common complaint.
Old 11-24-2013, 04:25 PM
Mein Auto: 335XI
Thanks for the reply.....car has about 89k on it. Never heard of blasting intake valves with walnut shells so that's a new one!
That's exactly what it was....thanks for the advice and I apologize for not doing a search first. Sometimes I'm not sure yet where to start with this car
Tony
Old 11-25-2013, 02:03 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
335 automatic transmissions start in 1st gear from a stop. Many people think they start in 2nd because they count shifts to top gear without realizing that the transmission will skip gears along the way.
Easy to check. Start from a stop. Accelerate slowly, watching the speed and RPM at the time of the first shift. Then use manual mode to find the gear where that speed / RPM combination occurs.
Even easier, watch this video.
My car had the same symptoms as the OP. It needed the intake valve cleaning, and at 89K, so does the OP's car.
Old 11-25-2013, 03:52 AM
Miller335 Miller335 is offline
Mein Auto: 2007 E92
Silly automatics.
Old 11-25-2013, 07:04 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Gosh-a-mighty man! Immediately DO THIS
Due at 60k and not a warranty item, dealer charges ~$600.
Attended U/D - are you looking at early flurries this year?
Old 11-25-2013, 01:07 PM
Mein Auto: 335XI
I did the manual/auto test a few times today. The car is as smooth as can be in the manual mode. I watched when I felt my hesitation and it appears right when it shifts. That walnut blasting might be something I do when I have some time and it warms up!
Originally Posted by Miller335 View Post
Silly automatics.
Agreed......the wife had to give up a six speed Firehawk because of Baby
The car is a CPO certified car......wouldn't this need to be done to maintain the warranty to 100k? When I talked to the dealer they said it was still covered.
It's cold as can be here and we had flurries the other day. Hopefully that's it for the year
Tony
