Old 11-25-2013, 11:09 AM
cjadkins17 cjadkins17 is offline
Mein Auto: 2011 BMW 535i xDrive
Wheel Offset Questions
I have looked through the forums and cannot find the exact answer I am looking for about wheel offsets.
I have factory 18" spoke wheels that have a +30MM offset. I am looking to get M5 replica wheels that have a +35mm offset. Will there be an issue with these new wheels, or will the fit OK? Thanks!
Old 11-25-2013, 11:19 AM
gicamuci gicamuci is offline
Mein Auto: 535i xDrive
See this link:
Rims calculator
Regards,
Alex
2012 w204 Mercedes-Benz C350 4MATIC MY 05/2012 Obsidian Black/Sahara
2011 F10 535i xDrive MY 01/2011 Sophisto Grey/Black
Old 11-25-2013, 02:09 PM
Based on that site, I should be OK. It says "Package is 5 mm (0.2'') closer to suspension/brakes components. Acceptable for most cars." I am guessing that the 5mm difference does not put that wheel in any jeopardy of hitting the caliper. Thanks for the link.
Old 11-25-2013, 02:56 PM
Technic's Avatar
Technic Technic is offline
OEM Audio PnP Integration
Mein Auto: 2017 M3
Offset is only meaninful if the wheel width is also included in the calculation.
Old 11-25-2013, 03:07 PM
Factory wheels are 18 x 8 all around. After market are 18 x 8 in the front and 18 x 9 in the rear, both with a +35mm offset.
Old 11-25-2013, 04:09 PM
Technic's Avatar
Mein Auto: 2017 M3
The fronts will be 5mm tucked in and the rears will be 8mm closer to the fender vs OEM.
You may need a 5mm spacer in the front just to keep the wheels as poked out as the OEM's. A 12.5mm spacer will make the fronts flushed with the fender.
Old 11-25-2013, 04:20 PM
Ok, thanks for the info. I have the option to get the same wheels with a +20mm offset. Is that a better option?
Old 11-25-2013, 04:25 PM
Technic's Avatar
Mein Auto: 2017 M3
Those are going to poke a lot...
By the way, I will be selling my F10 M5 19" replicas with Michelin A/S 3 245/40 -19 with less than a month/800+ miles of use this week if interested. They are 19 x 8.5 ET35 all around, no nicks, rashes but no TPMS.
I got the 20" version coming this week, that's why I will be selling this set.
