Old 11-25-2013, 11:56 AM
throwaway365 throwaway365 is offline
Mein Auto: tbd
Considering an '08 335i w/problems
I have a few questions about a 335i I am considering buying used not CPO. I have taken the car on a short test drive and right away I could tell that something was wrong. It felt like it was in limp mode (warning light was on/I don't know the codes thrown). I checked the service history through a local BMW dealer and it shows that the High pressure pump (HDP) has failed on two separate occasions (at 37,xxx mi and 45,xxx mi). Currently at 76,xxx mi. Is this a HPFP failure that its experiencing now? Would the SIB B13 03 09 warranty extension be honored for a 3rd owner of the vehicle? Thank you for any help you can give.
Old 11-25-2013, 12:57 PM
bocabimmer's Avatar
bocabimmer bocabimmer is offline
Found the Search Button
Mein Auto: 2007 E92 328i, 2013 X5
Is the price that attractive that it's worth having issues that may/may not be HPFP related?
2013 X5 35i
2014 i3 BEV
2007 328i (E92) - BMW Performance exhaust, short shift kit, handbrake and steering wheel trim - CDV delete - CREE LED corona rings - LED license plate lights
2006 325i (E90) - SOLD - projector headlights, blackline taillights - satin grilles - shadowline trim - style 338 wheels
2000 ML430 - SOLD - heavily modded, I miss that truck
Old 11-25-2013, 02:03 PM
Mein Auto: tbd
The seller seems to be aware of the issue (and hasn't been able to sell it) but I would be using the problem as leverage to lower the price. Maybe I should continue my search elsewhere...
Old 11-26-2013, 02:18 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Find an indy with a BMW compatible reader and have the actual code pulled. It may be something worth dealing with, it may not.
If it is the HPFP, the warranty extension should not care how many owners the car has had.
Old 11-26-2013, 03:46 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
THIS typically done @ 60k mi - was it?
Old 11-26-2013, 05:40 AM
Mein Auto: tbd
I only have repair history from the 1st owner (who had things taken care of at a BMW dealer). The last thing it was brought in for at 53,xxx mi was an N54 injector check (defect code 0013970100). I am going to guess and say valve cleaning hasn't been done. (unless it is 85990201MP)
Old 11-26-2013, 05:58 AM
Mein Auto: tbd
Getting the code will be the next step. The two defect codes from previous failures mentioned above are 1351901200 and 1351651200.
