Old 11-25-2013, 03:52 PM
Mishimoto Mishimoto is offline
Mein Auto: BMW
Mishimoto 335i Intercooler Testing!
The engineers at Mishimoto have been busy testing one of our latest products, the 335i performance intercooler. We dyno tested this intercooler multiple times, performing 4th gear, and 1st-4th gear pulls.
We tested several different core configurations to find the most optimal core for these cars. The final result was a 22% thicker core, with a 35 degree reduction in AITs, and a gain of 21hp and 24tq!
Check out the engineering report for the full write-up.
http://lib.store.yahoo.net/lib/yhst-...ringreport.pdf
Let us know your questions and comments below.
Thanks,
Tyler
Steven Bryson
Old 11-25-2013, 07:33 PM
TXFred TXFred is offline
Mein Auto: 2008 335i Convertible
Why was there a 20 degree difference in inlet temperatures between the stock intercooler and yours? Your outlet temperature is lower, but so was your inlet temperature. It makes it difficult to judge the effectiveness of your intercooler.
Frederic
Any idiot can be fast in a straight line. The corners are what separates the drivers from the commuters.
Old 11-26-2013, 08:47 AM
JMEngland88 JMEngland88 is offline
Mein Auto: 2007 335i
Yea according to your little graph, the outlet temperature in relation to the inlet temperature is nearly the same between the stock intercooler and your aftermarket one. If the case truly is that the runs done with your aftermarket intercooler were done with lower intake temps, that also could negate the gains that you're claiming. A run done with a 20 degree lower intake temp with the stock intercooler could very well make a decent amount more power than one with higher temps. Is the higher intake temp due the piping leading up to the intercooler heat soaking?
Not saying the intercooler is junk or anything, don't get me wrong, just trying to clarify
Old 11-26-2013, 08:54 AM
bighorns's Avatar
bighorns bighorns is offline
Evil cider brewer
Mein Auto: E92 335i M Sport
This is why I love these boards: someone here will always ask the right questions.
http://www.bimmerfest.com/forums/image.php?type=sigpic&userid=325723&dateline=1371746393
*NEW* delete pls 1K
3K
11K
Old 11-26-2013, 12:09 PM
bear-avhistory's Avatar
2014 435M-Sport/MPPK
Mein Auto: 2014 435M-Sport/MPPK
Agree, the response should be interesting
Kevin
CURRENT:
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2014 BMW 435M-Sport MPPK/MPE 8ZF
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
470 WHP of BURBBLES
HOME FROM PAINT
Old 11-26-2013, 12:47 PM
Mein Auto: BMW
Frederic
Great question! The reason our inlet temperatures are different is because the graphs are based off an average of 3 dyno runs. The temperatures were equal at the first run for both the stock and Mishimoto intercoolers. During the testing, the car was given 3 minutes between each run to cool off.
Due to the all-aluminum construction of the Mishimoto Intercooler, it had the ability to dissipate heat more efficiently, allowing the car to cool down quicker. The stock intercooler was heat soaking, which caused the inlet temperatures to be higher than ours. Hopefully this helps, and please let me know if you have any other questions.
Thanks,
Tyler
Steven Bryson
Old 11-26-2013, 03:09 PM
I am not understanding something. I can see heat soak effect the output side, by why would it effect the input side?
Kevin
CURRENT:
470 WHP of BURBBLES
HOME FROM PAINT
Old 11-26-2013, 04:34 PM
ModBargains IV's Avatar
ModBargains IV ModBargains IV is offline
Mein Auto: e92, e82, e46, e39
Maybe condensation build up? Usually that's the most common issue with most of the intercoolers available in the market.
Just my .02.
-Frank
Old 11-27-2013, 06:34 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Have not looked into available FMIC's, but do know something of heat exchangers and condensation....no trap on these units?
FAIL!!
There's gotta be pain in Florida.
Old 12-03-2013, 03:50 PM
Mein Auto: BMW
Our sensors were placed on the actual end tanks, at the opening of the inlet and outlet. If you look at the design of our end tanks vs. the stock intercooler, you can see that our end tanks are formed for more efficient air flow. Because of the geometry of our end tanks, and the larger internal volume of our intercooler, the heat is able to disperse more effectively, causing lower inlet temperatures. This, combined with the heat soak effect I explained earlier, is why there is a difference in the inlet temperatures during our testing. Hopefully that clears everything up.
Thanks,
Tyler
Steven Bryson
Old 10-19-2014, 01:21 AM
kthxtyler kthxtyler is offline
Mein Auto: E90 M3
FAIL!!
Mishimoto...what is he referring to exactly?
Old 10-19-2014, 07:30 AM
rdkind62's Avatar
rdkind62 rdkind62 is offline
Mein Auto: 2011 BMW 335is, 2015 X1
Are you asking what a Mishimoto is or what he is saying? If you are asking what a Mishimoto is, in this case it is a name brand for a FMIC (front mount intercooler). There are lots of them out there. If you are asking what he is talking about I'll let you ask him that one.
BMW 335is, Cobb tune with VRSF intercooler, Injen CAI, and BMS downpipes. 382/414 rwhp/tq. Le Mans blue with Black Dakota leather, Convenience and Premium packages, 19" wheels, 7 speed DCT, heated seats, Nav., Harmon Kardon Logic 7 stereo w/ Satellite radio. 2015 BMW X1 28iXdrive M Sport, LeMans Blue, with Black Dakota leather, Premium and Technology packages, with heated seats, satellite radio.
Old 10-19-2014, 12:25 PM
Mein Auto: E90 M3
I'm asking him to address the issue asked by CAL. Haha. I'm in the market for an FMIC and want to know what I'm getting should I choose a Mishimoto.
Old 10-19-2014, 12:33 PM
galahad05's Avatar
galahad05 galahad05 is offline
Better with Butter
Mein Auto: 335i sedan 6MT
Looks like Cal is talking about a condensation trap to me. His Florida rainstorm pic is used to highlight his point--hot humid air compressed further then sudden cooled = condensation. Where does this water go?
Don't resent growing old. Many are denied the privilege.
-- Irish Proverb
