Old 11-25-2013, 06:24 PM
big_cat big_cat is offline
Mein Auto: 2007 BMW 328i sedan (E90)
Engine Swap
I am looking into an engine swap for my E90 328i. I was curious if an M5 engine would fit. If possible where would I be able to find an affordable engine, either whole or part by part. Thanks.
Old 11-25-2013, 10:11 PM
lqaddict's Avatar
lqaddict lqaddict is offline
Salz und Pfeffer
Mein Auto: 2014 F22 M235i
Engine Swap
Fit like the engine mounts, all electronic gizmos, ECU, etc? Or fit like throw it in the engine bay and close the hood? If later the answer it will fit with some wrecking effort. Will it blend though?
BMW CCA Member 454031
Save the manuals
Old 11-25-2013, 11:17 PM
Kinda both. I assume that it will require some work, with hooking up those components. I guess what I want to know is if the engine itself would fit in with engine bay with moderate work, or will I need to spend a couple of days (or weeks) trying to fit it in there.
Old 11-26-2013, 12:10 AM
tturedraider's Avatar
Freedom isn't free!!
I think you'd be better off, financially and otherwise, to just buy a 2008 ///M5.
www.bmwcca.org
Old 11-26-2013, 02:07 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
V10? Mike's done it - give him a PM
Difficult transition as I recall.
Affordable?
Old 11-26-2013, 08:33 AM
twhisten twhisten is offline
Drive it like u stole it!
Mein Auto: 2016 M3
Probably be cheaper and easier to just by an M5. Sounds like would be way more work. Would chassis be able to handle the much greater HP? Wider tires?
1997 328i- retired
2007 328i- retired- lease
2006 330xi- retired
2011 335xi-PCD-12/13/10 - DINAN3-----retired
2013 M3-Laguna Seca-6 speed-EDC ------retired
2016 M3
2006 X5- retired
2011 X5- retired- buy back
bmw cca#443379
Old 11-26-2013, 09:03 AM
Banned
Mein Auto: 2007-335 HTC
now if you were putting a BMW engine in a MG or Triumph, or a Datsun 240Z, or in a 2002 model would be cool but I wouldnt want to mess with what you want to do
Old 11-30-2013, 07:54 PM
Thank you guys for all the info. I probably am just going to go out and buy this M5. Thanks again.
Old 11-30-2013, 10:38 PM
What's important about V10?
Old 11-30-2013, 10:40 PM
Keepittrill's Avatar
Keepittrill Keepittrill is offline
My avatar is a selfie LOL
Mein Auto: 2011 M3 DCT
Engine Swap
When it's all said and done, you're probably looking at WELL above $20K in parts and labor.
BUY A MANUAL E60 M5. They're out there, trust me. There's 2 for sale on the west coast now.
2010 E89 Z4- gone and forgotten (;
2011 M3 DCT
'14 C7 Z51 3LT M7
20 and blessed.
Old 12-01-2013, 05:38 AM
dmatre dmatre is offline
Mein Auto: 2011 E90 328i
Engine Swap
Affordable? M5? Really?
If you're serious about big hp swap, go for a small-block Chevy or 302Ford.
Much cheaper to find/maintain and can easily surpass hp of V10.
Old 12-01-2013, 06:47 AM
need4speed's Avatar
need4speed need4speed is offline
Mein Auto: 16 435 CV Msport PPK/335d
Originally Posted by tturedraider View Post
i think you'd be better off, financially and otherwise, to just buy a 2008 ///m5.
+1 n4s
Old 12-01-2013, 10:03 AM
Mein Auto: '06 AW 330xi
Hartge did it:
