Old 11-26-2013, 11:49 AM
mcaval10 mcaval10 is offline
Mein Auto: 2008 328i convertibele
Angel eye problem
Hello,
I bought led angel eye replacements and installed them, they were a dark blue, on each side one angel eye lit up well, while the other was very dim, so I returned those and ordered some brighter halogen lights and installed them, they worked fine for a couple of days, and then I was getting a symbol on the dash that a light was out, one angel eye was dead, replacing with a good bulb does no good, one side is working while other side is not. Might there be a fuse out ( I did check the ones I thought it could be) but did not find a bad one. Why would one side work and the other not ( I did put a working bulb in the non- working side with no help) thanks for any help/suggestions.
Mark
Old 11-26-2013, 01:00 PM
Mein Auto: '06 AW 330xi
If the bulb was out for awhile, the FRM will shut down that circuit.
It needs to be reset via a diagnostic tool, such as winkfp.
