E36 (1991 - 1999)
Old 11-29-2013, 01:53 AM
vengenz's Avatar
vengenz vengenz is offline
Mein Auto: 1999 328is
Ive had P0455 has been there since I got the car. The code only shows when I get below a quarter tank. I replaced all the ccv system. I checked for any leaks, but found none. Ill snap a picture of the injectors in the morning.
The part numbers for the o2 sensor is the same for all 4, could I swap the sensor throwing a code with a post cat sensor to check?
Old 11-29-2013, 02:55 AM
drivinfaster's Avatar
Mein Auto: rescued bmw's
no, not necessarily. it depends on *why* the code was set. if the code was set due to a dead/dying sensor, then you will wind up throwing catalyst efficiency codes by swapping it out with a secondary o2 sensor.
if it was set due to the dme being unable to curb in the fuel trim, even a new sensor will do nothing to get rid of the code.
you need to look at the fuel trim numbers in order to be able to determine this. this info should be displayed as 'ltft' and 'stft', long term fuel trim and short term fuel trim. long term is the parameter that will set when fuel trim is beyond factory specifications.
df
Old 11-29-2013, 03:28 AM
Nicky3 Nicky3 is offline
Mein Auto: 96 328is
Once again I'll mention that I had everyone of those codes at the same time when I was given my car. I had all kinds of vacuum leaks. The boot , hoses, you name it. I can almost assure you that a big vacuum leak is your problem. Blow some cigar smoke thru your brake booster hose and watch where it escapes from. Then sit back and enjoy the cigar knowing you found your problem. In my mind, a vacuum leak is the only thing that can cause your issue, after knowing all the parts you changed.
Old 11-29-2013, 01:00 PM
vengenz's Avatar
Will the AutoZone scanner show the fuel trim numbers?
And I checked for the vacuum leaks with the brake booster line, and nothing. Smoked a cigar in disappointment.
Old 11-29-2013, 01:19 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
No, it won't.
1998 BMW 328is
1966 Pontiac GTO
Old 11-29-2013, 09:26 PM
it should, as i understand the requirements for 'scan tools' to be able to do so. however, a 'scan tool' and 'code reader' are 2 different animals. depending upon the tool that the store uses, it might be able to show this information if the person using it has the ability to be able to use it properly.
however my experience has not been very positive in this regard, so i doubt that your experience will vary from this.
df
Old 11-29-2013, 09:31 PM
vengenz's Avatar
Im in good with a manager at AutoZone, anytime I come in he gives me the fany $300 tool and puts the cheap one back. It has live drive diagnostics so it should tell me what's up.
Old 11-30-2013, 02:11 PM
vengenz's Avatar
If the link works, this is the splatter. http://rs1312.pbsrc.com/albums/t531/...0?t=1385841980
Old 11-30-2013, 02:14 PM
Mein Auto: 96 328is
Are you loosing coolant?
Old 11-30-2013, 02:19 PM
vengenz's Avatar
Not that I know of. No overheating issues
Old 11-30-2013, 02:37 PM
Mein Auto: 96 328is
There is nothing in my mind that I can think of that will tie all those codes together accept a massive vacuum leak or a head gasket failure.
Old 11-30-2013, 02:58 PM
vengenz's Avatar
I did spot a small exhaust leak on the flange off of bank 1 headers. But its small
Old 12-02-2013, 06:57 AM
Leusent Leusent is offline
Mein Auto: 328is
I wonder if your DME got wet at any point? Might be worth a quick check to see if your drains are clogged up. If they are, I'd suspect DME.
Winter: 1997 DOHC I-6 2.8L 5Spd BMW 328is (2-Door)
Summer: 1992 DOHC I-4 2.0L 5Spd Toyota MR-2 Turbo (2-Seat)
Summer: 1983/1984/2007 Honda CB550SC/VF500F/CBR600RR (2-Wheel)
Old 12-02-2013, 11:24 AM
vengenz's Avatar
How do I check that?
Old 12-02-2013, 12:13 PM
vengenz's Avatar
Dme looks like its seen some water love.
Old 12-02-2013, 12:14 PM
Mein Auto: 96 328is
I think u found your problem.
Old 12-02-2013, 12:22 PM
vengenz's Avatar
How do I replace that? Aren't they coded to the specific car?
Old 12-02-2013, 05:05 PM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
Where in Arizona did you see enough water to get your DME flooded?!?!
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 12-02-2013, 05:14 PM
vengenz's Avatar
When rain decides to show its face here, it goes hard. Hahaha
Old 12-03-2013, 11:30 AM
hnaz's Avatar
hnaz hnaz is offline
BMW CCA Member
Mein Auto: 128i M, M3, 530i M
What kind of DME do you have? I have a spare silver label I can send you (if that's what you have), but you'll need to chip it for your car. I'd suggest a Turner one.
Harry // 1995 Avus Blue M3 - 2003 Titansilber 530i M Sport - 2010 Black Sapphire Metallic 128i M - Sport // BMW CCA #453346 - North Capitol Chapter // 2000 Silver Audi B5 S4
My Previous Work:
My 325is M-Tech Restoration Thread
My 98 M3 and 03 530i Restoration Thread
Old 12-03-2013, 11:33 AM
vengenz's Avatar
Im not sure. Whatever comes stock in a 96 328is. Could I pull the chip in it now and put it in?
Old 12-03-2013, 11:41 AM
hnaz's Avatar
BMW CCA Member
Not really. That chip is programmed for that CMOS on your current DME. But you can find out by pulling the DME out of the box (unplug the harness, two bolts on both sides, pull it out). Then look on the top (It will say BOSCH or SIEMENS). Different DMEs from Bosch will have different colors like Red, Silver/White, and Green. But I think yours might be silver. Red label was more for earlier cars.
Here is what I am talking about with Turner chips:
http://www.turnermotorsport.com/p-35...or-delete.aspx
They program the chip specifically for your car, mods, etc. And if you have problems, they have an amazing staff to help you troubleshoot. If all else fails, send the chip in, they send you another one, no questions asked.
But before all of that, you may want to pull your DME out, pull up on the tabs and remove the 4 torx screws (T8 I believe), and check inside for any moisture or corrosion or any type of previous moisture.
My Previous Work:
Old 12-03-2013, 12:56 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
You cannot chip a '96 ECU. It has to be reflashed. '95 was the last year for a removable chip.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 12-03-2013, 04:28 PM
vengenz's Avatar
the bottom of the dme, the top side looked fine. The dme is Siemens also.
Old 12-03-2013, 06:56 PM
yeah,.....that's not a good thing...
df
328is, e36, misfire
