Old 11-26-2013, 06:03 PM
tgbennett tgbennett is offline
Mein Auto: 2007 BMW 328I
Replacing valve cover gasket,
while i have this bad boy torn down is there anything else i should replace?
I plan on replacing the valve cover gasket, and the oil filter housing gasket.
Also any advice?
Thanks in advance,
Old 11-26-2013, 06:13 PM
kmorgan_260 kmorgan_260 is offline
Mein Auto: 1997 528i
Was it leaking oil, vacuum leak, why are you replacing the gaskets?
94 318I (Daughter's car), 96 740IL(current project), 97 528I(DD), 07 335I(Son's car)
Old 11-26-2013, 06:17 PM
It is leaking oil from both the valve cover gasket, and the oil filter housing gasket
Old 11-26-2013, 08:41 PM
Leekay07 Leekay07 is offline
Mein Auto: X5 35D, Former X1 and 335
replace the head bolts while you have it apart.
If you like customer service. Don't look beyond a BMW.
Old 11-30-2013, 09:23 AM
alichak alichak is offline
Send a message via Yahoo to alichak
Mein Auto: BMW X3 2004 2.5i
I had a leak from the valve cover gasket, I just replaced it. yet I had a strange issue...
the valve cover gasket did not sit fully flush into the edges of the valve cover, but when I tighten the screws, it was squeezed into the valve cover and now it is sitting nice and flush.
anyone had this issue? I even thought I might have bought an oversized gasket!
