E34 (1989 - 1995)
Old 11-30-2013, 12:27 PM
dave47561879 dave47561879 is offline
Mein Auto: 2011 535i 6MT
Help with my 1995 530i
So as you probably already know that this car has a 3.0L V8. After two days of owning the vehicle, the engine started to have zero performance and idle rough. Idle rough in the sense that the entire car is shaking. So I figured it might be spark plugs. When I went to replace the spark plugs, I found out that there was a little bit of oil on top of the plugs, and it looked as though the valve cover gaskets were leaking. So I replaced the valve cover gaskets and the spark plugs, but that did not fix my problem. Upon further review, I figured out that the entire right side of the engine isn't firing. The spark plugs are good and the ignition coils are good, but there is no spark on the right four cylinders. How would I proceed in diagnosing this issue?
Old 12-01-2013, 04:43 PM
calysporot95 calysporot95 is offline
Mein Auto: 2001e49, 94e34
I drove my 530i daily for eight years. A leak in the air intake side of the system is likely. The big tube can crack and the leaks letting unmetered air into the system. Also look for a loose stainless hose clamp anywhere on the intake side.
I don't know of anything that would cause loss of spark on one side of the engine. Check the grounding strap on each ingnition coil. If all are positive check the grounding of the entire engine. The orange gaskets between the intake plenum and the heads crack and fail causing similiar unmetered air problems. There is a gasket at the back of the air plenum (I can't remember the name of the part)- it has a hose going to it. It can also cause unmetered air. Mine is a great car.
Others are more expert. Leaking air is likely the problem. Get a Bentley's manual. Many topics thatbturn up as quesions are covered in Bentley. i have read a way to find an air laek is to spray carb cleaner or starting fluid onto the outside of likely failure points. If the engine revs a bitnyou may have found the loacation of the air leak problem.
Old 02-24-2014, 12:05 PM
mgfranz mgfranz is offline
"You chose wisely..."
Mein Auto: E64, E38, Boxster, A4
Yup! One reason I got my E34 for so cheap was that it was running really rough at idle, when I popped the hood I saw that there was a missing clamp on the intake side of the inlet. Of course I didn't say anything to the seller... $2.10 later and the engine was purring like a kitten.
Old 02-24-2014, 07:38 PM
imae34driver imae34driver is offline
Resident e34 Racer
Mein Auto: 1995 540i SPORT /6 spd
Zero spark from an entire cylinder bank??
Sounds like the DME is toasted to me.
Bone stock 95' 540i/6 Blk/blk w/ ram style C.A.I / JBR LWFW/ DUDMD tune/ straight pipe /545 SSK /3.15 LSD / Rev-shift motor mounts/stage 4, 6 puck clutch/ K Sport coil overs/Eibach sway bars/ VAC under drive pulleys/weight reduction /sparco 368, Recaro seats, sparco harnesses, NX wet kit, M/T E/T streets.
"Skill can only get you so far, then comes money!"
R . I . P Paul Walker - 1973 - 2013
1995, coils, e34, idle, ignion, plugs, problem, spark, v8
