Old 12-04-2013, 10:05 AM
jlittle67 jlittle67 is offline
Mein Auto: 2012 328i Sport
2008 328i battery reset
When I crank my car after it's been sitting for a few hours it acts like the battery has been disconnected: the time has to be rest and the brake lamp failure/fuel supply malfunction/trailer lamp malfunction light comes on. If I drive for a while the warning goes away. I've been having some problems with the battery charging as I've been spending most of my time on a military base where the speed limit is 35 mph. I found that this problem went away for the most part after I made a long road trip and the battery charged for an extended period of time. It came back after a few days. Could this be related to the battery somehow?
Old 12-04-2013, 10:59 AM
Mein Auto: '06 AW 330xi
It's your driving habits. The car doesn't charge the battery under 2k rpms or somewhere around that range.
35mph is too slow to get rpms up higher than 2k.
Invest in a battery tender.
Old 12-04-2013, 12:07 PM
So when I go back to normal driving it will probably fix itself?
Old 12-04-2013, 12:21 PM
Yes and no. If the battery has been discharged for a while, and it's a lead acid, the plates inside are most likely sulfated, decreasing battery performance/life.
Once you start driving normally, take the battery out and have someone charge it. If you can use a tender that would be best because it can repair the battery but it will take a couple days.
If you're still having issues after charging, replace the battery.
Alternators are never suppose to fully re-charge a heavily depleted battery. For starters it would take way too long. Secondly, you're straining the electrical system.
Old 12-05-2013, 05:53 AM
The service engine soon light came on this morning could that be related to this issue?
Old 12-05-2013, 06:14 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Yeah, could be. CODE CHECK - any BMW Indy should have that or GT1. Shucks, I have one - maybe you should too!
Do you qualify for the Battery Cable Recall? Otherwise, yeah, could be your battery:
Yeppur, cold weather usually brings on a rash of "What's the snowflake icon mean?" and "Is my battery bad?" threads.
When was your battery last replaced? What, never?!? Dude! When you replace it, [click here for procedure], an inconvenient R&R in the German tradition.
BUT! If you don't want to wrestle that honkin' big box o'lead out of your trunk, consider BATTERY DESULFATING
Many part series on battery desulfating:
Name:  Mechanic 01 [20].jpg
Couple more useful views:
__________________________________________________
EDIT: NEW device to test voltage over time under any condition - VERY useful....
Old 12-07-2013, 02:19 PM
So I replaced the battery and it's still resetting any thoughts?
