E36 (1991 - 1999)
Old 12-05-2013, 03:14 AM
wazung wazung is offline
Mein Auto: E36 320i
Adjustable rear camber
Hi all,
I am looking at fitting Eibach pro kit springs to my 320 sedan. I have been told that they give about a 30mm drop from standard, which I believe is about M3 height.
Ok, so the question is, do I need to fit adjustable rear camber arms or would this be an overkill?
Any thoughts would be appreciated.
Old 12-05-2013, 11:04 AM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
Only if the stock adjusters don't allow enough adjustment to get back to around -1.5 degrees after the lowering springs are installed. If you go for a performance alignment then you might need the camber arms if you can't get to -2.0 degrees or more in the rear.
If you can get to -1.5 degrees, regardless I'd look at spending some money on camber adjustment in the front as you'll get more handling improvement from that than additional camber adjustment in the rear.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 12-05-2013, 11:52 AM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
If you're only going to be sitting at about M3 height, you won't need any adjustable camber arms or plates.
1998 BMW 328is
1966 Pontiac GTO
