couple of questions on a 99 318ti (newbie) - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 12-07-2013, 06:59 AM
blewbyu318ti blewbyu318ti is offline
Mein Auto: dodge cummins
ok so I got this car its a 99 318ti, I have not owned a bmw since the late 80's so my knowledge base is limited and I need help. I bought this car from the previous owner who had a kid help him jump start this car and for what ever reason put the battery cables on opposite of what they should have been. The guy states they were on for the amt of time it took him to get from drivers seat to battery and disconnect them. The car will now not run no fuel no fire all the other things ie lights etc work as they should but when the car is being rolled over to start there is no attempt at all to fire. I am not willing to just throw money at this car to get it going I am trying to educate myself on the car and wanted to ask people who might have some idea of the extent of the damage this may have caused and what I can do about it. If the cost is too great I will just have to cut my losses as I have more important things ie family that require my time and money. Any help is greatly appreciated
I've asked specifically what the po has done and ;
The previous owner stated that he thought the ecm was damaged and purchased another from ebay and installed it only to have the same issue. He stated that from his research the ecm would need reflashed ?
I have been able to power up the fuel pump with the relay but cannot get the car to generate spark
I wondered if the security system may have been damaged when the power was appled incorrectly not sure how I would test this theory
The issue causing the battery to be low has been corrected (improperly installed aftermarket stereo ) the car ran great after stereo install but poor connection allowed a drain on the battery (cheap black electrical tape on pwr connection)
The battery is new and fully charged rolls car like it should and all the obvious grounds have been checked and in good shape
Old 12-07-2013, 11:25 AM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
Welcome to the fest!
The ECU is toast. Likely the security system, too. Yes, the ECU has to be matched to the car, but I don't know exactly how you go about that. Someone else here will know. If it's an automatic it may have killed the transmission control computer, too.Not good.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 12-07-2013, 11:27 AM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
If your battery was really drained then there's a good chance of polarity reversal on the 12v supply to all your electronics. It could be a fried DME module. If the EWS was cooked I don't think you'd get the engine to turn over. If you get it running I suspect you'll find other control modules that have been damaged. If your windows still work then at least the ZKE module didn't get cooked.
This is one of those things that could be a simple fix or you could wind up having to replace a bunch of stuff......there's not much precedent for giving you advice on this one unfortunately.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 12-07-2013, 11:43 AM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
I once made a similar mistake in my younger days while working on an old MG Midget. Although I still don't accept full blame... They have reverse polarity electrical systems, just to make things "interesting".
1998 BMW 328is
1966 Pontiac GTO
Old 12-07-2013, 12:01 PM
D'oh, You Kids!
So does my 1963 John Deere 2010 tractor. There have been several "Oh SH!T!" moments when trying to jump it off.
Quotes to live by:
BMW-CCA #441426
Old 12-07-2013, 12:04 PM
dc_wright's Avatar
There were a lot of older cars that were positive ground. VWs up through the early '60s were 6V systems and we got a lot of them into the shop where someone had installed a 12V battery by mistake. It usually blew all the indicator bulbs, tail/brake light bulbs, and all the filaments on the vacuum tubes in the radio. The starter did spin the engine over quite briskly though.
Old 12-07-2013, 12:50 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
no doubt!!
yeah, i have had the pleasure of working on 6v positive ground vehicles.....stoopid electrical gremmlins....
to the op, yeah, this sounds like a bunch of issues that may or may not be self inflicted. the first thing to do is check for blown fuses, then go from there with basic electrical diagnostics.
you need to check the wiring diagram for your powers and grounds, and then check for the proper power supply to the correct pins.
tedious work.
very tedious work....
df
Old 12-07-2013, 01:04 PM
questions
thank you gentlemen I have been dreading this for obvious reasons time being the biggest issue but I have checked the fuses that I know about I will be getting a manual and digging out the meter for more fun. I am grateful for the replies and will post my progress in hopes of getting this car going again back to the man cave
Old 12-15-2013, 07:42 AM
update
still working on this it seems odd to me the only way I can obtain a ground is by hooking my meter to the neg terminal on the battery. normally I would say just not getting a good connection but nothing even on the ground strap itselF. Now if I hook up the battery ground it then immediately completes the circuit. Logic dictates the ground is the culprit however I cannot find any damaged wires so heres the newbie question is there a fuse in the ground wire and if so where is it ?
Old 12-15-2013, 04:14 PM
no fuses in the ground side of the circuit.
if the cables arc when hooking them up, then something is causing a short to ground directly.
i would verify that the cables are hooked up correctly, and that the power cable(s) are not crossed with the ground. if all of the main power supply cables (thick heavy ones) are where they are supposed to be, then i would suggest unplugging connectors on the harnesses to see which harness is causing the issue and narrow it down from there.
other than that, i am unable to come up with anything else.
df
