Mystery oil leak - any ideas? - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 12-07-2013, 01:53 PM
wschwisow wschwisow is offline
Mein Auto: 2001 325i
Hey all,
I have a 95 325is that is leaking oil and I can't figure out where from. I posted a video on youtube showing where all the oil is ending up. I'm thinking maybe the fan is shooting it everywhere, but I can't find a location. I cleaned everything up first and then drove it to get a better idea, but it seems to be everywhere on the passenger front end. Any ideas?
Old 12-07-2013, 02:19 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Hmmm... That's a lot of oil in some unusual places. First thing I'd do would be to check the seal at the oil filter housing, particularly for the cap. And I'd also take a close look at the VANOS oil line.
1998 BMW 328is
1966 Pontiac GTO
Old 12-07-2013, 02:29 PM
drive by72's Avatar
drive by72 drive by72 is offline
I feed trolls
Mein Auto: 3 series
Strange indeed.
Carb clean everything off, including underneath. Start car with it raised and with a good flashlight, look very closely at all seals. Valve cover gasket near the vanos, vanos oil pressure line, and the oil filter housing area.
My vanos oil pressure line had a small seep at the crimp from rubber to metal, that leak drove me nuts for months. It wouldnt cover the passenger wheel well but it did get in the fan and in the fireproofing, and kidney cover.
Best of luck and let us knlw
RIP Ben "Jever" Doebele, we wont forget you
Please, call me Chadley
1997 328iS... HR coilovers, Brembo F40 calipers, camber plates... I sure do miss you
1990-somethin Chevy K3500... Twin turbo Cummins swapped Chevy, dana 60 front axle swap, 4 link rear, air ride, custom everything. 600+ hp, 1296 ft lbs tq
Old 12-07-2013, 02:42 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
I think the oil is getting blown up on the under-hood insulation from where ever it's leaking, then running down through the fibers onto the front firewall/radiator support. There's nothing ahead of the radiator to leak oil into that area.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 12-07-2013, 03:45 PM
Normdude's Avatar
Normdude Normdude is offline
Mein Auto: 2003 530i Sport
They sell a dye you can use to find it
Clean everything, put the dye in the oil, and shine a black light and you'll see where it's coming from
Old 12-07-2013, 08:51 PM
hnaz's Avatar
hnaz hnaz is offline
BMW CCA Member
Mein Auto: 128i M, M3, 530i M
Check the oil filter housing. I am willing to bet that is one of the main places. Then the breather hose. Then maybe the VANOS oil line.
Harry // 1995 Avus Blue M3 - 2003 Titansilber 530i M Sport - 2010 Black Sapphire Metallic 128i M - Sport // BMW CCA #453346 - North Capitol Chapter // 2000 Silver Audi B5 S4
My Previous Work:
My 325is M-Tech Restoration Thread
My 98 M3 and 03 530i Restoration Thread
Old 12-15-2013, 02:16 PM
JayMac JayMac is offline
Mein Auto: 01 M3, 83 320is, 75 2002
Clean it again. Stuff shop towels everywhere except the exhaust. Short drive check to see which ones are wet with oil. I have had vanos leak, engine cover, oil filter.
Old 12-15-2013, 04:41 PM
I'll give it a shot. Thanks.
Old 12-15-2013, 04:49 PM
I hate oil leaks! Good luck
Old 12-15-2013, 07:18 PM
outlander108 outlander108 is offline
Mein Auto: bmw 325IS E36
last time i had oil on that part of the car was from the oil filter housing...if you changed your oil filter recently make sure you use 2 copper washers instead of one and make sure the oil housing is really tight...
Old 12-17-2013, 03:43 AM
bimmer claus's Avatar
bimmer claus bimmer claus is offline
Santa
Mein Auto: 95 M3
Isn't there an oil return on the side of the block or something along those lines as well. I remember reading a post a while back similar to this and it was something on the side of the block. I'll try searching to find it for you.
Lots of junk.
Old 12-17-2013, 08:43 AM
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
Is there any oil on the fan? Could be leaking from valve cover, hitting the fan and throwing it everywhere.
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2007 328i DD
