E30 (1982 - 1993)
Old 12-07-2013, 03:45 PM
omarphi215 omarphi215 is offline
Mein Auto: 1991 525i Auto
Lots of work need help..have not driven for two weeks
Ok so I need tie rods, struts, and rear brakes with rotors...I was quoted in the area of 6-700 bucks. I'm on a budget but should I Upgrade? Perhaps upgraded brakes..higher end struts maybe? I have an auto convertible..it's my daily driver so what can I do to make it more fun? And so certain brands make that much of a difference? Honestly I would be happy to have a car the rides smooth again. Also anyone know of any deals or should I just rely on what the mechanic gets as far as parts are concerned?
Thanks in advance
Old 12-07-2013, 08:29 PM
cmac2012's Avatar
cmac2012 cmac2012 is offline
Renaissance Dude
Mein Auto: Two 1987 325i, 430K, 211K
Could be at that price he's using after market. Do you mean the front suspension part containing the coil spring when you say strut? I haven't priced those lately but they're not cheap. I don't think any mod in those parts would make your car more fun to drive. OEM parts if bought at a discount house might be a way to go - I'd ask the guy what kind of parts he's using.
Old 12-07-2013, 10:40 PM
downhiller's Avatar
livin large
the only thing there worthy of upgrading is the struts. but youve gotta change springs in order to get that performance out of them. since it the rear brakes, no need slappin cross drilled or slotted rotors cause they only provide 30% of stopping power. front brakes are a different story. IMO stick with oem replacement stuff for now
Old 12-08-2013, 05:23 AM
BMWFatherFigure's Avatar
Old School
+1 with downhiller
Current:
E38 Parts Car
Previous:
Old 12-08-2013, 05:49 AM
Thanks that helps a lot.
Old 12-08-2013, 08:43 AM
toybuilder's Avatar
toybuilder toybuilder is offline
Mein Auto: 89 325i 2dr&DucatiMonster
Maybe see how much more your mechanic will charge to install Bilstein HDs they will give the car a better/sport ride without changing the springs. They're just a bit stiffer than stock struts if you replace the rears as well it will really make a difference .As for the rest of the parts OEM is the way to go.The OEM struts are Sachs/Boge and usually cost almost as much as the Bilsteins.(retail)
