E30 (1982 - 1993)
Old 12-07-2013, 06:15 PM
`66 coronet `66 coronet is offline
Mein Auto: bmw `88 320i convertable
Unhappy auto gearbox problem
hi, I have a 320i convertible with an auto gearbox the problem I`m having is when cold it holds onto 1st gear either until warmed up a bit or high revs, once it has changed gear it works fine. I have changed the fluid and the strainer,it is a little better than it was but still the problem remains I have read a thread on here were some people say it is the catalytic convertor, the only prob there is my car dosent have one! I would appreciate any help as I am going mad with this,it is either pressure related or temperature
Old 12-07-2013, 11:45 PM
downhiller's Avatar
livin large
all my autos did that, even my 04 silverado does that. i think thats more ecu flash oriented versus problem. there could be something else goin on, but if it shifts fine after it warms up and the fluid level is fine, then i wouldnt worry too much about it
Old 12-08-2013, 02:33 AM
the only trouble there is my gearbox is non switchable so I don`t think there is an ecu attatched to the gearbox?
Old 12-08-2013, 02:36 AM
I think you are right though, I might be worrying about something I can`t fix,but it`s not so bad!!
Old 12-08-2013, 06:22 AM
BMWFatherFigure's Avatar
Old School
My E23 has the same problem. My trans wizard tells me a likely cause is a worn (then twisted) 'o' ring in the valve body - it jamms the shift control piston.
Current:
E38 Parts Car
Previous:
Old 12-09-2013, 07:48 AM
thanks for that.I`ll just live with it then I don`t fancy my chances of getting hold of or being able to identify that then. Ive changed a valve body on my `66 dodge coronet for a full manual body but I would`nt like to fiddle with the seperate valving etc!!
Old 12-09-2013, 05:39 PM
downhiller's Avatar
livin large
most autos have some sort of ecu control. the rest are pressure related with help from the throttle position/passing gear. so in essence, if its cold, the fluid is thicker causing higher pressures which holds gear longer. on newer cars, the ecu/tcu(?) when the engine is cold will run the rpms higher, warming the engine faster which warms the tranny faster too, or at least from what ive heard/read
