2007 65K miles 328xi running very rough - Bimmerfest - BMW Forums
Old 12-08-2013, 10:52 AM
machtnichts machtnichts is offline
Mein Auto: 2011 328i xdrive
So I just started up my car after about three days leaving it alone. It idles very roughly and has less power. The unevenness lessens at higher speed, but I won't drive it above 25mph until I know what's going on. I suspect a bad spark plug or wire is causing one of the cylinders not to fire. I am getting the yellow 'service engine soon' light, not a more urgent one.
What do we think-
Is it safe to drive? How far, how fast, how long? I have to go to a job 90 miles away tomorrow but there is a good mechanic there I could take it to. Or do I only dare drive it slowly to the local guy? Would a sensor cause a more urgent message if there were a lot of danger, or should I trust my common sense that this is too uneven to drive very far? I know people drive big old V8s with missing cylinders, but I suspect those engines tolerate that abuse much more readily.
Where I drive.
Old 12-08-2013, 01:20 PM
EmawBMW EmawBMW is offline
Mein Auto: 2007 328i
I had this same problem with my 04. Ended up being a problem with one of the intake hoses. Had a hole and sometimes caused the car to shut off. Now I'm sure there are more things that cause this issue but fwiw
Old 12-08-2013, 03:13 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Sounds like the solenoid issues some N52 owner have experienced. Search here and see what you find.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 12-08-2013, 05:04 PM
It seems like a very consistent unevenness, not like intermittent missing.I still suspect cylinder(s) missing. I think I will rent a car for my trip tomorrow and try to sort it out later this week.
Where I drive.
Old 12-09-2013, 06:22 AM
Mein Auto: '06 AW 330xi
Scan the dme. Stop guessing. The fault codes will more than likely point you in the right direction.
Old 12-09-2013, 04:03 PM
It was the ignition coil for cylinder #6. Indy fixed it in an hour.
Where I drive.
Old 12-09-2013, 05:28 PM
R1200 R1200 is offline
Mein Auto: 328XiT and R1200C
Good call to rent and not drive that distance with a misfire. Raw fuel entering the catalytic oven creates a blast furnace and big problems.
Don
328XiT Sonora
