Antifreeze.... - Page 2 - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 12-14-2013, 10:00 AM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Originally Posted by chet31 View Post
I highly doubt there is anything special about BMW anti-freeze.
Oh my, don't say that. We have had heated debates in the past about this. Some pretty smart folks who know BMW will say it is in fact very special.
I used to not worry about it, but I must admit, since moving to BMW blue only, I have seen less failures of cooling system parts.
Green in a pinch, blue for everything else.
I dare say distilled water and a can of redline water wetter is better than the green stuff.
Old 12-14-2013, 12:25 PM
SJBimmer's Avatar
SJBimmer SJBimmer is offline
Living Life At The Beach
Mein Auto: 2004 325 Convertible
Re: Antifreeze....
You finally came around huh? Lol I too am now a believer in using only manufacturer specific fluids. I used to only use the green in all my cars, and always had rads failing early, ect. Since doing regular changes with the correct stuff, I have had almost none of that.
Old 12-15-2013, 03:18 AM
QAfred QAfred is offline
Mein Auto: 328i, 330ci, R1200C
I totally agree, and now use BMW antifreeze and have less problems...many of the OEM parts you order will even state warranty does not apply if you do not use BMW antifreeze! I was not a believer either, but now I use the blue hsit (OEM fluid) and have less problems, much less. I dunno why?
Old 12-16-2013, 12:52 PM
chet31 chet31 is offline
Mein Auto: 05 330i convertible
I too use BMW coolant, so I'm talking out of both sides of my mouth here. However, as a chemist, I am simply skeptical that BMW invests the R&D that would be required to re-invent something as ubiquitous as coolant.
Also, if using a certain coolant results in fewer cooling system failures, is that not an indictment of BMW coolant? What coolant were we all using the first time we had a cooling system failure?
Old 12-16-2013, 01:23 PM
smolck's Avatar
ROLL TIDE!
I used to have a lot of Tstat issues with the green stuff (prestone IIRC). Since running my ZHP I have always used the BMW stuff. My OE radiator is still going at 203k miles. I do flush the system annually because it is so frigging hot down here.
I finally came around as it relates to coolant. I still could give a rip what BMW says about oil. Partly because they list it for NEW BMW engines. I would argue that the oil requirements of my 203k mile motor are different than a 60k mile motor.
Old 12-16-2013, 02:43 PM
SJBimmer's Avatar
I agree that oil is not as critical since it is (supposed to be) changed more often.
Old 12-16-2013, 07:42 PM
chansta chansta is offline
Learning Daily
Mein Auto: 89 CIVIC
i recently got a 325i and the lower hose blew off on me on my way to the detail shop. found green coolant all over the place so went ahead n fixed it n put blue.
iATN
Old 12-20-2013, 06:46 PM
Tebpac Tebpac is offline
Mein Auto: 2005 325xi
Update....
Had the local dealer read the codes this AM. Oil Separator leak! Had it fixed today. After reading some of the supposed daunting but doable task to DIY this problem, I decided to wait for a psuedo easier DIY project to start with. I know, I'm a wuss. Antifreeze level is still ok. Thanks for all the input (and future input).
Todd
2005 BMW 325xi
