E36 (1991 - 1999)
Old 12-08-2013, 05:35 PM
thudsonjr's Avatar
thudsonjr thudsonjr is offline
Troy "Thud" Hudson Jr
Mein Auto: 1996 BMW 328is
Blower motor quit working
The fuses are all good and my digital controls all seem to be working but my motor just doesn't turn on. Is there anything to look for before I fork out the money on a new blower? Also will the blower out of a 4 door work in a 2 door?
1996 328is 5speed
-Montreal Blue Metallic
-17" ASA JH3
-VIS Racing Carbon Fiber hood
-DJ Auto Projector Housings with Predator Chromium AE and
55w 10k HIDs, Clear M3 corners
-M3 replica side mirrors
-Summit race buckets
-Raceland Headers
-Raceland Ultimo Coilovers
Old 12-08-2013, 05:51 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
I think the blower motors are interchangeable between all body styles, but verify the part number on RealOEM.com beforehand. Also, you can run a jumper to test your blower motor without having to replace it. You may just need a relay or final stage unit.
1998 BMW 328is
1966 Pontiac GTO
Old 12-08-2013, 06:09 PM
thudsonjr's Avatar
Which relay is it? I can't find a diagram that tells me
1996 328is 5speed
-17" ASA JH3
-Raceland Headers
Old 12-08-2013, 06:10 PM
thudsonjr's Avatar
It seems lie a relay. Because my motor has never squeaked or showed any signs of failure. All of a sudden it stopped working. So I wouldn't think it's the motor. And is there a way to test the FSU?
1996 328is 5speed
-17" ASA JH3
-Raceland Headers
Old 12-08-2013, 06:18 PM
hornhospital's Avatar
D'oh, You Kids!
Failure mode for the FSU is usually the fan defaulting to full speed continuously regardless of where the switch is set above "off". Probably not the FSU.
Quotes to live by:
Old 12-08-2013, 06:27 PM
ZeGerman's Avatar
Warm Leatherette
I think it varies a bit. When my FSU died, sometimes it would blow on max when I had the speed set to low, and other times the blower motor wouldn't run at all despite being set to max. I was under the impression that it's the earlier OBD1 cars with resistors and not FSUs that the fan speed defaults to max when the part dies. But anyway, I'd check your relay and blower motor before buying anything.
1998 BMW 328is
1966 Pontiac GTO
Old 12-08-2013, 07:34 PM
thudsonjr's Avatar
I fixed it. My relay was "stuck" so I tapped it and I'm all good. For now.
1996 328is 5speed
-17" ASA JH3
-Raceland Headers
Old 12-08-2013, 09:14 PM
ZeGerman's Avatar
Warm Leatherette
Yeah, they can need a little "waking up" every now and again.
1998 BMW 328is
1966 Pontiac GTO
Old 01-01-2014, 04:01 PM
Mojuice98 Mojuice98 is offline
Mein Auto: 318i
where is the relay for the blower motor located, I am having the same problem where my fan only blows on high. I have spend 3 hrs taking apart the dash looking for the FSU on the passenger side and it not being there and now i could not find the resistor on the driver side. ready to set the whole car on fire.
Old 01-01-2014, 07:03 PM
D'oh, You Kids!
Mo, I'll give you a dollar for it and take it off your property rather than you burning it.
The relay is #9 in this diagram:
Name:	E36 Relay locations.jpg
Quotes to live by:
Old 01-01-2014, 10:47 PM
Mein Auto: 318i
Thanks, I replaced that relay with a new one and the fan still Blows only on high. my buddy replaced the blower motor with a used one, I am thinking maybe both are completely done. ANy thoughts?
Old 01-01-2014, 11:23 PM
D'oh, You Kids!
It's the final stage resistor gone bad. Just like you were told in the other thread you posed the same question (don't do that, please)
Quotes to live by:
