E36 (1991 - 1999)
Old 12-08-2013, 05:35 PM
Noelair24 Noelair24 is offline
Mein Auto: 1995 325is
Replacing Catalytic Converter 1995 325is
I am replacing my faulty Catalytic Converter I found one from someone parting their car out. Their car is a 97 325 convertible. Shouldn't be a problem right? Should fit? I wanna make sure before I buy.
Old 12-08-2013, 06:21 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Since the 325 was replaced by the 328 in '96, there is no such thing as a '97 325. There was also a transition from OBD1 to OBD2, and because of that, if you're using the entire midpipe from the '97 including the cats, you will have some additional oxygen sensor bungs which will need to be plugged if used on your 325.
325 midpipe:
328 midpipe:
1998 BMW 328is
1966 Pontiac GTO
Old 12-08-2013, 06:32 PM
http://images.craigslist.org/01515_g...Ja_600x450.jpg
This is the one they are selling me
http://inlandempire.craigslist.org/cto/4204492094.html
Old 12-08-2013, 06:37 PM
325 midpipe:
328 midpipe:
You see my response?
Old 12-08-2013, 06:53 PM
southpark11235's Avatar
southpark11235 southpark11235 is online now
bimmerfest Supporting Member
Mein Auto: 1999 BMW 323is
Originally Posted by Noelair24 View Post
That is a 323 exhaust which is restrictive. You should wait for a real 325 or 328 exhaust. Also the seller is an idiot. "V6 engine"
Alex//1999 323is - power e46 M3 seats, style 43 rims, 328 exhaust, Z3 rack, Bilstein PSS coilovers
//1992 Mazda Miata - cat delete, power windows, oil filter relocation
“We got about ten minutes before this entire county is up in flames. If you want to live, you’d better step on the gas! Oh wait is this a Tesla? Sh!t! Well, step on the prissy pedal, we're going to die!” – Cartman
Old 12-08-2013, 07:59 PM
ZeGerman's Avatar
Warm Leatherette
And I repeat, there is no such thing as a '97 325. The seller doesn't know what he's talking about, which is further backed up by the fact that BMW has never made a V6 engine...
Nevertheless, it will fit your car.
1998 BMW 328is
1966 Pontiac GTO
Old 12-09-2013, 12:18 AM
Restrictive in what way?
Old 12-09-2013, 12:19 AM
Thanks a lot! Appreciate the help on the info.
Old 12-09-2013, 02:07 PM
In between the headers and muffler the exhaust twitches to a single pipe, which is more restrictive than the dual pipe M3/328/325 exhaust. In order to remove the extra 22 HP from the 323, the only parts BMW changed versus the 328 are the exhaust, tune and crankshaft.
Old 12-09-2013, 02:41 PM
ZeGerman's Avatar
Warm Leatherette
Well sure, but a difference in the cylinder stroke is significant.
1998 BMW 328is
1966 Pontiac GTO
Old 12-09-2013, 06:24 PM
So what do you guys recommend I do? If I put the 323 it will slow my car down then right?
Old 12-09-2013, 06:34 PM
ZeGerman's Avatar
Warm Leatherette
Eh, there's probably a bigger difference between the 323 & 328/M3 midpipe than there is between the 323 & 325. The 328 and M3 midpipes are the only ones which don't bottleneck into one tube, so if you're considering going from a 325 midpipe to a 323 midpipe, it won't be a very big difference, if any.
1998 BMW 328is
1966 Pontiac GTO
Old 12-09-2013, 06:59 PM
My 325is has a dual exhaust on it
Old 12-09-2013, 07:48 PM
will this 95 m3 cat fit mine? Guy is asking 300 for it. What do you guys think?
http://orangecounty.craigslist.org/pts/4223383243.html
Old 12-09-2013, 08:01 PM
That cat will easily fit your car. Around here $300 is way over priced. I paid under $100 for my 328 cat and muffler. However, I do not know your local market, so you will have to use your judgment on that one.
Old 12-12-2013, 11:31 AM
OK I got it for 280. So when I change it I wanna replace all the oxygen sensors. How many of them is there? And where could I find em for a good price? I found a lot of good stuff on eBay. Km thinking there. Just need to know how many it is.
Old 12-12-2013, 11:40 AM
^Just one right before the cat.
Old 12-12-2013, 11:43 AM
OK thanks. Do you recommend I replace all the oxygen sensors tho?
Old 12-12-2013, 11:47 AM
ZeGerman's Avatar
Warm Leatherette
Your 325 is OBD1, so I believe it just has one pre-cat O2 sensor and nothing else. This means that you'll have a lot of unused oxygen sensors on that midpipe you just bought. You can either just leave them in place and not connected to anything, or you can remove them and install bung[holio] plugs.
1998 BMW 328is
1966 Pontiac GTO
Old 12-12-2013, 12:11 PM
"all sensors" . I just told you, you only have one. If the sensor is working fine, I would not replace it. However replacing it will not hurt anything.
Old 12-12-2013, 12:19 PM
Thanks a lot guys. I'll keep you guys updated on my replacement
Old 12-12-2013, 04:12 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
that pic wasn't a 95 anything,....it was obd2, which is 96 and newer.
as for the o2 sensors, there are only post cat sensors on the obd2 exhausts, which monitor the efficiency of the cats and will not have any input in the obd1 chassis.
you will need to either weld in a bung for the o2 sensor (use the inboard pipe), or use an obd2 manifold, which is where the o2 sensors go on od2 cars.
as for cats, you could have gotten one from bosal for just over 300, and although it is listed as not for sale in cali, i think that is splitting hairs over hypocritical since buying used is just as verbotin....
df
Old 12-12-2013, 04:41 PM
df
which pic?
This guy has a 95 and 99 Cat
I'm buying the 95 one for my car. Its off a M3
Old 12-12-2013, 04:49 PM
the pic you have listed is obd2. look at the sensors behind the cats, before the resonators.
there is no o2 sensor bung before the cats since the obd2 sensors were on the manifolds, and there are 2 cats.
95 will only have 1 sensor, and be be a 2-into-1 before the cat, not 2 pipes with 2 cats as the picture you posted.
df
Old 12-14-2013, 07:58 AM
vmaxman vmaxman is offline
Mein Auto: 95 325i
$280 for used cats?? i bought 2 brand new magnaflow cats that are CARB compliant for $70 a piece, and they flow much better than stock cats. I bought them on amazon Good luck on the used ones you purchased, i hope they are still good.
jason
1995 325i SOLD
Black 18" Hamman wheels
umnitza exhaust
M3 bumper
