E36 (1991 - 1999)
Old 12-08-2013, 07:46 PM
Tkaczuk's Avatar
Tkaczuk Tkaczuk is offline
if it wasn't for that...
Mein Auto: M3, & The Wabbit
Possible ac compressor seized?
Hey guys, my daily M50 had some trouble coming home after a long trip last week. I've been busy so I didn't get a chance to take a look. Tonight I went out and after some investigation think that possibly my compressor seized up.
In traffic the car shut off. I got it going again and got off the road as soon as I stopped it shut off again. I start it one last time to get to a better location and after that point it wouldn't start up again. I knew my water/alternator pulley was going bad to I figured that was the problem. To tonight I loosened the belt and discovered it was free so I loosened the compressor belt and I couldn't move the compressor at all.
Two part question
1. Any other possible problems?
2. Can I run the car without the compressor belt on correct? Not effecting anything?
Any input would be great.
Old 12-08-2013, 08:03 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Yeah, you can run the car without the A/C belt installed, but I wouldn't think that a seized A/C compressor would be able to prevent the engine from running. Seems like you'd just roast the belt off rather than stopping a 190hp engine in its tracks.
1998 BMW 328is
1966 Pontiac GTO
Old 12-09-2013, 07:08 AM
Tkaczuk's Avatar
I'm not sure what else it could be. Its something belt driven. If I try to start the car I hear a belt squealing the engine is turning over and firing.
Old 12-09-2013, 08:08 AM
Leusent Leusent is offline
Mein Auto: 328is
I would be tempted to cut off the $10 belt and see if everything gets better... just don't cut the wrong belt
Winter: 1997 DOHC I-6 2.8L 5Spd BMW 328is (2-Door)
Summer: 1992 DOHC I-4 2.0L 5Spd Toyota MR-2 Turbo (2-Seat)
Summer: 1983/1984/2007 Honda CB550SC/VF500F/CBR600RR (2-Wheel)
Old 12-09-2013, 08:36 AM
ZeGerman's Avatar
Warm Leatherette
Don't cut any belt. Just remove the A/C belt.
1998 BMW 328is
1966 Pontiac GTO
Old 12-09-2013, 08:51 AM
Mein Auto: 328is
Thats better advice. Listen to ZeGerman.
Old 12-09-2013, 09:15 AM
Tkaczuk's Avatar
I took it off last night. Not hard to do. I want to replace the water pump pulleys while I'm in there.
Old 12-09-2013, 09:48 AM
hursh328ic hursh328ic is offline
Mein Auto: 96 328ic
my bubbies cadilac had the ac compressor seize up and it stopped his engine.
i wouln't have belived it either but the car wouldn't even turnover. i took the tension of the belt and the car started right up. release the tensioner and the car stalled again
All the days you don't drive your BMW you don't get back
Old 12-09-2013, 11:05 AM
ZeGerman's Avatar
Warm Leatherette
Yeah, I guess it must be possible then. It's hard to imagine a 190hp engine being stopped in its tracks by a small rubber belt that isn't even 1-inch wide, but I believe you.
1998 BMW 328is
1966 Pontiac GTO
Old 12-09-2013, 12:00 PM
hornhospital's Avatar
D'oh, You Kids!
The 4-banger in the '87 Celebrity I had was stopped dead by a seized AC pump while driving down I-10 at 80 mph! It was an automatic so it more or less coasted a bit, I put it in neutral and I realized what it was. As soon as I turned off the AC I could restart the engine and drive home. It made a hellacious noise and smoke when it locked.
Quotes to live by:
Old 12-09-2013, 12:03 PM
Mein Auto: 328is
I seized a compressor on my '95 neon. The car barely started and the idle was bad for about 5 seconds until the belt broke... then everything was fine. Guess it can go either way.
Old 12-09-2013, 12:07 PM
D'oh, You Kids!
The belt on the 4-cylinder is THE belt, as in only one. If it had broken, I'd have been stranded. It drives the PS pump, water pump, alternator and AC compressor, so it's a big, wide multi-groove belt.
Quotes to live by:
Old 12-09-2013, 12:14 PM
Tkaczuk's Avatar
I hope that's the problem. I'm going to put it back together and see what happens later today. The compressors probably is stock and the car has over 200k.
Old 12-10-2013, 11:46 AM
Tkaczuk's Avatar
It was the compressor. Took the belt off. Put the other pelt back on and it started right up. Got some more power now that its not trying to turn that. Thanks for the help guys.
Old 12-10-2013, 11:52 AM
ZeGerman's Avatar
Warm Leatherette
Glad to hear it was an easy fix.
1998 BMW 328is
1966 Pontiac GTO
