E30 (1982 - 1993)
Old 12-11-2013, 06:13 PM
charlesE30E34 charlesE30E34 is offline
Mein Auto: Canada
Need help! E30 swap with V8 M60B30
hello there. I have a v8 3 L M60B30 from an e34 bmw... I have the entire car in parts and i would like to swap all of it in my 4 door e30! My question is will the e34 driveshaft fit in my 1987 325 car (e30)?
Old 12-12-2013, 09:22 AM
downhiller's Avatar
livin large
i believe no. e34 had a longer wheelbase. might send a pm to garagistic. theyve done the v8 swap and have kits to make the swap easier
Old 12-12-2013, 10:16 AM
Newman271's Avatar
Newman271 Newman271 is offline
That Guy
Mein Auto: 99' 540i M-Sport
Also, a reputable driveshaft shop can make you a driveshaft from 200 to 300 bucks. I also believe the e34 driveshafts have different u joint flanges and uses a larger guibo I believe.
1999 540i M-Sport
Silver/Black
Still fresh and Minty
1985 335i
Black on Black coupe 5spd
R.I.P
1979 Trans Am 10th Anniversary
#16 of 5,683 made
KOI Import Parts-- 513-771-7777
Old 12-12-2013, 02:00 PM
Mein Auto: Canada
Ok! Thank you guy's i'me going to go do some mesurments... Got an other question thow... If I put a v8 4L... the M60B40 instead of the 3L M60B30... Will the standard 530 transmission fit with the 4L 540 engine?? Thanks in advance
Old 12-12-2013, 07:57 PM
3star 3star is offline
Mein Auto: 89 E30 Cabrio
im not sure for the v8s but im currently swapping the E34 m50 power train into my e30. yes the driveshaft is longer but the transmission itself is super short. like much shorter than the auto trans i had originally
The answer is it depends on the tranny and you wont know till you swap it. also the input flanges on the diff will be different and you will need to swap those over.
Old 12-15-2013, 06:35 PM
garagistic's Avatar
garagistic garagistic is offline
Mein Auto: e30
This guide will help you:
http://garagistic.com/index.php?page...6x-into-an-e30
