The X5 SAV Forum
Old 10-04-2004, 07:39 PM
pseto's Avatar
pseto pseto is offline
Mein Auto: e92 M3 ZCP, M Roadster
Safe from thieves?
Can anyone give their opinion about how easy/hard it is to steal an X5? I have a 2002 4.4i, and I assume that its as safe as my e46. I know it has the auto disabler if oem key isn't used, but what other concerns should I have?
Old 10-04-2004, 07:44 PM
UCrewX5's Avatar
UCrewX5 UCrewX5 is offline
Member of the club
Mein Auto: BMW X5
Popping the lock is very easy to do and unless you program your vehicle so that only using the remote to unlock the vehicle (versus the key) will keep the alarm from going off, you are vulnerable.
One solution to the door lock pop problem is to eliminate the key - http://www.janixworld.com/x5/DoorLock/
Old 10-04-2004, 08:22 PM
breytonX5's Avatar
breytonX5 breytonX5 is offline
Hog Town
Mein Auto: 14 F10, 14 F15
It's gonna be extremely difficult (if not impossible) to steal an X5 or any other modern BMWs with built-in engine immobilizer, at least not by the old-fashioned way. If a (pro) thief wants your car bad enough, he'll find a way to get it. The new craze in car theft now is using a tow truck or breaking into your house and use the car key to drive your car away.
I have a cellular-based vehicle recovery system in my X5 in case it got stolen. But hope it never happens.
Old 10-05-2004, 05:34 AM
TripleX5 TripleX5  is offline
Member of the club
Mein Auto: Imola RedII 4.8iS - 733i
You have no idea how easy it is to steel these rides. Trust me when I tell you this...
Of course I wont go into details but as mentioned have your dealer disable the option of having the ability to disarm the remote via door lock and a simple fuel cut-off switch would be sufficient.
Ed (TripleX5)
02 4.4 retired
Old 10-05-2004, 07:15 AM
tq2k's Avatar
tq2k tq2k is offline
Yeah Baby!
Mein Auto: 2004 X5
Thumbs up
In Ed we Trust!
TQ2K
the "X" - '04 X5 - Alpine White/Truffle
the "M" - '03 M5 - Petrol Mica/Champagne
Old 10-05-2004, 11:16 AM
hayaku hayaku is offline
Mein Auto: Ketchep
i'll explain it cuz there are curious minds out there that want to protect their cars...
there are lots of key remote duplicators that you can buy very cheap... get one of them and just stalk your prey.. when they disarm their alarm to get in, voila... captured signal for your use whenever you want... same with garage door openers and such...
google is a blessing and curse at the same time. i got my black belt in google too. thats why i take my engine out and take it with me when i park my car.
Old 10-05-2004, 11:21 AM
UCrewX5's Avatar
Member of the club
Mein Auto: BMW X5
Old 10-05-2004, 11:29 AM
IFlyX5's Avatar
IFlyX5 IFlyX5 is offline
Mein Auto: '15 535i MSport
ROLFLMAO
2015 535i MSport Space Gray/Black Nappa | Driver Assistance | Premium | HK Sound | Heated Front Seats
Old 10-05-2004, 11:34 AM
Kewl X5's Avatar
Kewl X5 Kewl X5 is offline
Let's Get It Started!
Mein Auto: Only BMWs
Talking ROFL! Of course, you keep your V1 still attached!
Now, do I leave the motor mounts with the car or the engine?
Old 10-05-2004, 11:40 AM
alee's Avatar
alee alee is offline
Super Moderator
Mein Auto: '13 E92 M3, '01 E46 330Ci
Loading the vehcle on a flatbed is the easiest way to steal a BMW. Driving it off, next to impossible especially since all the keys are encoded with a transponder chip (including valet and plastic key). Duplicate keys cannot be ordered without substantial proof of ownership. There are 10 (?) keys produced per DME... once you lose your 10th key, you need a new DME. If I'm remembering correctly, new keys must be "added" to the vehicle as well -- I do not believe you can start the car without initializing the key first.
Capturing the remote code is also not as easy as using a scanner, as BMW uses a rolling code system. A captured code is one that is already used. 10 failed attempts, and the car will lock out all attempts for 15 minutes. Each key has its own independent rolling code. If the key is in your pocket and the button accidentally gets pressed, the code increments. If the codes are out of sequence but within a reasonable number of codes out of sequence the car unlocks. If the codes are further apart (like you pressed the button 100 times), then it will take 2 button presses to unlock the door (first one to try and re-sync, second one to unlock). If the codes are way off (like thousands of presses), the key must be reinitialized.
The most common way of entering a BMW is by "popping" the lock. Without the alarm properly encoded, a popped lock will also disable the alarm. There are also your more traditional methods such as prying the door open, breaking the window, etc. When your car is broken into, most thieves seem to target the glovebox -- a surprising number of people leave their plastic key in there or the leather car manual holder. They are also looking for your address, so they can find your house and steal your key at a later time. Since this is really the only way you can drive off in a newer BMW, protect yourself and don't keep important information in your car.
In short, car is easy to break-into. It is fairly difficult to steal without just picking up the car and moving it.
2001 E46 330Ci - 42K miles, 2013 E92 M3 - Back from PCD
Thinking about doing European Delivery? Read about my ED experience. Best trip, ever.
Similar Threads
Brand new car - swirl marks - SAFE to detail? BMW_Brand The Detail Department 6 07-09-2004 09:41 AM
Safe Trip to everyone going to HC2003 bob lindquist E36/7 Z3 (1996-2002) 3 08-22-2003 03:16 PM
safe to drive without underbody plastics? LiKe_WhOa! 1M & M2 8 05-16-2003 03:22 PM
