E30 (1982 - 1993)
Old 12-14-2013, 03:39 PM
TexHog188 TexHog188 is offline
Mein Auto: 2001 330CI
1990 325i - Crack in Instrument Cluster Lens
My instrument cluster has a crack in it and I would like to replace it. Can you buy those anywhere without having to purchase the entire cluster or cluster housing?
Also, if I have to buy the whole cluster, are they pretty much compatible, model to model? I've got a 1990 325i, Coupe, with VDO cluster. (Has Anti-Lock Brakes light indicator on cluster)
Old 12-15-2013, 08:08 AM
toybuilder's Avatar
toybuilder toybuilder is offline
Mein Auto: 89 325i 2dr&DucatiMonster
If you end up buying a new dash pod ,as long as all the components in yours work you could swap your parts into the new dash pod as long as it's for an e30 325i VDO pod then everything will be plug and play.I have seen lens but I don't think they're intended to be removed so I guess somebody just got lucky and you could glue to your dash pod.Look on Ebay I thought I saw one the other day(lens).Just be careful taking yours apart.
Old 12-15-2013, 11:15 AM
cracked cluster lens
