Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X3 F25 (2011 - current)
The latest X3 brings added style and new features to the BMW's mid-sized SUV. Talk about the BMW F25 X3 with other X3 owners now!
Old 02-06-2014, 10:13 AM
RhoXS RhoXS is offline
Mein Auto: Z3 & X3
Originally Posted by ngrigoriev View Post
BTW, I think I (at least me personally) can close on this battery issue. I have a solid proof both stalls we had have absolutely nothing to do with the battery. So it was all BS from the service to get me out of the door, at least the first time. After the issue with PDM was identified I have stopped charging the car frequently. Recently I did a test: did not charge it for a week, driving my usual routes, turning all the heating stuff I needed without any hesitation. So? At the end of that week we had pretty warm day and the car was doing ASS when it was about -0.5C outside. Not that I liked the fact that it was stopping the cold engine (!) when it was less than +3.5C, but the fact that it was doing it proves that the battery charge was quite sufficient. And after that I have connected the CTEK charger. So it went from the phase 3 to phase 4 very quickly, which means that the battery was most likely at 90% or more.
I have been avoiding making any more comments because too many people still seem to think the system is poorly designed. However, I think what you said above validates my argument. The electrical system in the X3, including the charging function, when everything is functioning properly, is robust, works very well, is capable of charging the battery, and easily handles a heavy vehicle electrical load. If there is a need to charge the battery with an external charger, then something is not working properly and needs to be fixed. Obviously, from the large number of posts regarding this topic, there are some components that do not appear to exhibit the high degree of reliability that we have every reason to expect. There appears to be an especially high failure rate in very cold weather. Nevertheless, when everything works as designed, the system needs zero driver attention either to manually charge the battery with an external charger or to manage/minimize electrical load. Since automotive batteries are designed to recharge quickly and the total starting energy is delivered in a very short period of time (just seconds), the battery gets recharged to the desired state during even relatively short trips. Needeing to charge a healthy battery at highway speeds for long drives is a myth. By the way, starting an engine only uses, worst case, less than 5% of the total battery capacity.
Old 02-06-2014, 11:43 AM
ngrigoriev ngrigoriev is offline
Mein Auto: X3 xDrive35i
Yes and no, I think. From my recent experience - it is not as bad as the dealer (!) presented it to me. Look, they themselves started blaming the battery and "poor profile" first, while the issue was different, a components, as you said. So, the dealers themselves use this explanation as a blanket to get rid of some complains that, in fact, require deeper investigation. That's one thing. The dealers themselves sometimes artificially make this issue appear to be worse than it is!
As for the quality of the design, I still believe that anything that fails that frequently is poorly designed. I am not a car engineer, I am a software engineer. If I was to design the system, I would first ensure that whatever is expected to sleep sleeps well until it is needed. And that the system includes enough watchdog timers and diagnostic tools to detect any unwanted activity that drains the battery. Battery, started, basic car components - this is the most important stuff. GPS, telematics, media player etc is extra. The car is locked, start the countdown timer and watchdog. If the current exceeds certain value after that - check individual components, force their shutdown/restart/whatever. 3 failures like this - write diagnostic code, display the service light. I would rather have navigation or bluetooth not working than having a car that cannot be started while I am 300km from home because of some software glitch. All these (or similar) design principles of the embedded systems are well known for many years, look at the cellphones like Nokia that can work days on a single charge.
I would not release a system where this rule is not properly enforced. So, to me it is an example of bad design - not necessarily of the entire system, but some of its components. I think it is about the ability of a particular company's engineering department to make an advanced, complex and, yet, simple and reliable system.
Old 02-06-2014, 01:48 PM
poker838 poker838 is offline
Mein Auto: F25 x28 n52 + n20 / B8 A4
We're on the "cutting edge" of new technology .. we're the guinea pigs / beta testers.
Old 02-06-2014, 04:09 PM
gregwym gregwym is offline
Mein Auto: X3 xDrive28i 2014
Haha, like ur logic. Im a software engineer too!
Premium + Nav Pack | Bluetooth Audio Streaming | Video in Motion | Auto Mirror Fold/Unfold | Auto Door Unlock | Flashing Emergency Brake Light | Close Trunk w/ Button & Key Fob | Digital Speedometer | 30L/100km Fuel Meter | Gear Indicator in DS mode | M Starting Screen
Old 02-06-2014, 04:22 PM
Mein Auto: Z3 & X3
... it is an example of bad design - not necessarily of the entire system, but some of its components. ...
I think you hit the nail on the head. This appears to me to be a hardware issue, not a system design issue. In my opinion, and it is just an opinion based on what I have seen a properly working system do, it is indeed a very well designed system. However, one or more of the components (different from system design) have some hardware weaknesses that become apparent in cold weather. Also, based on what I have seen in these forums, I think the hardware issues are limited to a module called (I think) a PDM that is located in a relatively unprotected area of the engine compartment.
Even if 99.99% of X3s never have a problem, there are so many out there that the very small percentage of failures that do occur become very visible. IMO it is remarkable that automotive manufactures are able to build cars as reliably as they do considering how incredibly many they manufacture.
Old 02-07-2014, 12:09 PM
The X Men The X Men is offline
Mein Auto: 2013 X3 35i
What you are describing is very similar to BMW's existing power management system, if you leave a dome light on for example, there is a watchdog timer, it will shut the light off after it times out. If battery is getting low, it will start to shut down non-essential components and keep shutting components off according to priority. Along the way there are numerous warning on the I-drive screen telling you that your battery is low.
Old 02-08-2014, 03:54 PM
mscamp's Avatar
mscamp mscamp is offline
Bimmer Dreamer
Mein Auto: 2011 X3
Just purchased a Deltran Battery Tender for our 2011 X3. It has been so cold here in Central Illinois and I have been only driving 20-30 miles per day. Went about 3-4 days without driving it as we used our new 2014 Siverado Z-71(replaced our 2008 Z-71 that was destroyed by tornado in November ( - yea it's been that kind of winter) to plow through the snow and cold. That's when the 'Low Battery Charge' warning appeared. Really don't want to be stranded in a parking deck.
2011 X3 - Purchased BMW of Peoria, IL October 6, 2012 - Deep Sea Blue/Oyster/Sienna - CWP1, CWP2, TP, PP, CP, PDC.
2006 X3 - Purchased BMW of Peoria, IL September 10, 2007 - Black/Black (Retired)
2006 330i Purchased BMW of Peoria, IL October 12, 2005 Arctic Met/Beige (Retired)
Old 02-08-2014, 05:53 PM
Gouda Gouda is offline
Mein Auto: 2011 X3 35i
I do the same thing with the same Deltran. Our X3 often sits for 3~ 5 days without being used. That coupled with extreme temps we have been having lately makes it just seem like a wise decision. Also, the SA at the nearest BMW dealer told me that I can expect 24 months additional service out of the battery by using a trickle charger. That alone makes it worthwhile to me. Never have seen a error message in winter. Might be a bit of a overstatement, but who knows.
2017 Ridgeline RTL-T
2011 X3 35i w/Michelin Primacy MXM4's
2008 Wrangler Saraha Unlimited
2007 C260 4Matic - sold
2006 350Z Roadster - sold
To many others to bother with...
Old 02-15-2014, 12:01 PM
PapaRocco PapaRocco is offline
Mein Auto: 2013 x3 35i
Fed up
I, too, am having issues with my 2013 X3's battery. I really have a problem with a car that cost over $55k that requires that I regularly charge its battery in cold weather. The car is in a garage at approximately 35 degrees and it loses its charge if I don't drive it for a few days. Then it will not allow me to turn my heater on--only the defroster. Is anyone else fed up a luxury car that won't let you turn the heat on?
Old 02-15-2014, 02:36 PM
Jennifer Natzel Jennifer Natzel is offline
Mein Auto: X3
Won't start periodically
I have a 08 x3 and I was out running errands and came out of the last store and my car wouldn't turn over. I got a jump and it fired right up. About a month later the same thing happened with no problems in between. I went and got the battery tested and it registered about 38% charge and the volts were fine they said. We have only owned the car since December and they put a new battery in it just before we bought it. Any suggestions?
Old 02-15-2014, 02:58 PM
02420X3 02420X3 is offline
Jennifer, for an '08 X3 you might get a better better response by asking your question in the 1st Generation X3 forum at http://www.bimmerfest.com/forums/forumdisplay.php?f=65 This forum is for the 2nd generation X3, 2011 and later.
Old 02-17-2014, 02:36 PM
What is a PDM?
My dealer was not familiar with PDM. Said he'd check, but I'd like to know.
Old 02-17-2014, 04:09 PM
Want the Thrill Want the Thrill is offline
Power distribution Module
Old 03-05-2014, 03:36 PM
desi_guru desi_guru is offline
Mein Auto: Bmw x3 2014 x28i
PDM replacement
I have brand new 2014 x3 with less than 5000 km and 2 days ago I received message on dash board for drive train malfunction. We ha cold weekend with -30 for 3 days in row. I have my car park outside but I do plug it in, since I live in Edmonton.
Monday I took my car to dealership and they informed me to leave car and have it checked.
Got back my car today with new PDM installed. Girl wouldn't tell the real cause o he system and she mentioned that lot of x3 having this issue.
So much trouble for having brand new car!!
Old 03-05-2014, 03:48 PM
Welcome to the club
"lot of x3 having this issue" - to me that would be the reason for the recall.
And, I am wondering, what are you going to do about that? How are you going to tell BMW about your "experience" ? NHTSA? Facebook?
Old 03-05-2014, 04:12 PM
jeff_K jeff_K is offline
Mein Auto: BMW X3 28i
The severe cold weather and snow must be really testing your cars. BMW has a lot to learn. I wonder if other brands of cars are facing similar issue. And I am sure you guys are aware that Jade Rabbit is also suffering from the extreme cold on the lunar surface; immobile and in hibernation if not already "dead".
Old 03-05-2014, 06:52 PM
Snow's not a problem unless you need to dig your car out first...and it's the problem for the back anyway Severe cold weather....well, that's something we have every year since the dawn of the history Fair, other brands probably face some other issues. So it is up to their owners to get angry - according to the severity of the issues.
As for Jade Rabbit...We are talking about the consumer products here (e.g. BMW cars), not about bleeding edge R&D devices. My life somewhat depends on the quality of this product. Literally, its bad design has a slim but real chance to kill you and your family. As horrible as it sounds, that's real. Jade Rabbit's failure on the moon could not kill anyone, unless there is some life out there
Old 03-12-2014, 03:58 PM
CA328 CA328 is offline
Mein Auto: 2015 X3 35i, 2013 328i
E70 X5 diesel here - I also got drivetrain malfunction and airbag malfunction warning 1.5 weeks ago. This was after it sat outside one night where overnight low was -42C with windchill. Normally the truck is parked inside in finished but unheated attached garage.
After 4 days it still wouldn't start (would crank but not fire), so had roadside assistance tow it to dealer. Dealer got it back to me same day (great service) - diagnosis was dead battery, which was replaced. As an aside they also performed a recall and oil change at same time without me asking - much appreciated.
Truck has run fine for the last week no problem. Outside temps have also warmed up significantly since that weekend the truck died.
Our other vehicle, 2013 328i, also warned us of increased battery discharge about a month ago on a cold day - but hasn't displayed the same warning since.
Other than the above incidents the vehicles have been flawless (aside from a flat tire on the X5, but that could happen to anyone).
Old 01-20-2016, 02:42 PM
ScottFM ScottFM is offline
Mein Auto: 2014 328xd
Originally Posted by AzNMpower32 View Post
I hope y'all realise that the battery charges best when drive on the freeway for extended periods; multiple short trips at urban speeds (<70km/h) won't do much.
Cold weather is just a killer on batteries, especially when you factor in seat heating, radio, climate control, headlights, etc....and don't forget all the other electric components (coolant pump, steering, etc...)
I got the message after a two hour freeway drive. Then I took a break and did a three hour freeway drive and still had the message. The next morning, even colder, I did not get the message
Old 01-20-2016, 02:47 PM
Second winter with Cadillac SRX and same usage pattern. No problems with the battery. Lets face it, it is a BMW design bug, not a general scientific problem
Old 01-20-2016, 04:33 PM
/dev/null /dev/null is offline
Mein Auto: 2014 X3 F25 xDrive 28i
If it's cold and I drive 10 miles or less, I do sometimes see thie battery charging message if the temperature in the low teens or lower. All those electronics must draw power like crazy if it can't recharge withon 15 minutes or so of driving! Once it warms up enough, the message goes away or if one drives a longer period of time.
Old 01-20-2016, 08:21 PM
little<><'s Avatar
little<>< little<>< is offline
B zzzz ZZZZZZZ zzzz
Mein Auto: X3 F25 N55
I have found that driving it in manual mode, and keeping the RPM's around 1800-2200 while driving seems to help, especially when the heated steering wheel, seat(s), and mirror & rear defrost are all going. The engine idles pretty low when driving, and I don't think the cold helps the battery and alternator keep up with all the large loads.
Old 01-20-2016, 08:53 PM
Cold and heat are the enemies of batteries. One saps the charge, the other saps the life. That big AGM battery in the rear of your F25 X3 is going to last about 4 years under average conditions, longer under better conditions, and less under extreme conditions.
Old 01-20-2016, 09:09 PM
Cannot argue with any of those statements. The problem is when it's cold is when you use all those extra devices, not to mention the windshield defroster and rear window defroster. These days, 4-5 years is about the most you get out of most batteries (my all-time record was 12 years, but it was in a vehicle I rarely drove).
Old 01-21-2016, 01:01 AM
biterror biterror is offline
Mein Auto: 530dAx
I don't believe using electric devices when the engine is running really affects battery charging in modern cars. I have measured the charging voltage at -30 C on two cars (Saab 9-5 and BMW F11) with lots of electrical load when the engine was idling and the voltage was almost 15 volts (measured with a Fluke true rms multimeter). When voltage is above, say, 13-13.5 volts, the battery is not discharging, but the electrical loads are supplied by the alternator.
The problem is that at low temperatures, the battery requires a higher charging voltage AND it doesn't accept high charging currents. If you look at page 19 of this document http://www.lifelinebatteries.com/manual.pdf you'll see that at low temperatures, AGM battery must be charged at voltages of 16.3...16.88 V. The highest charging voltage I have seen on my F11 has been 15 V which means the battery will never get a full charge, no matter how long I drive.
When the battery is cold and I drive for 1-2 hours and then stop the engine, my F11 always tells me to charge the battery. When the battery is initially warm, there are no error messages.
I have been thinking of installing a battery heater, but I'm not sure if it's worth installing it to the old battery, so I haven't got one yet.
