E30 (1982 - 1993)
Old 12-14-2013, 06:24 PM
BANSHI BANSHI is offline
Mein Auto: 91 325i bmw
Exclamation 91 bmw 325, NOISE PROBLEM, VIDEO INCLUDED
Timing belt broke causing valves to bend. I had the machine shop fix the head. I put a new timing belt on and adjusted the valves. heres the result
I think there's a valve that wasn't replaced correctly
take a listen,
_a_
Old 12-15-2013, 08:51 AM
toybuilder's Avatar
toybuilder toybuilder is offline
Mein Auto: 89 325i 2dr&DucatiMonster
How did you adjust your valves Hot or Cold? Are you getting oil through the squirter line above the rockers ?Did the shop check the valve springs ?
Old 12-15-2013, 06:39 PM
I adjusted the valves when cold, I'm pretty sure oil is getting to through the line. But the machine shop only replaced the valves and rocker arm, not the springs or anything else. Could a spring be the cause of the noise?
Old 01-02-2014, 08:24 PM
BigBoy740il's Avatar
BigBoy740il BigBoy740il is offline
Mein Auto: 1989/1991 E30; 2000 E38
Re: 91 bmw 325, NOISE PROBLEM, VIDEO INCLUDED
I don't think so. If you adjusted your valves to specs, you should be able to rotate the engine three times and come up with the same tension between the valves and rocker arm eccentric with the camshaft and crankshaft in proper alignment. To me it sounds like loose valves or low lubrication.
Big Boyz with Bad Toyz.
Old 01-04-2014, 02:45 AM
toybuilder's Avatar
You need to adjust the valves cold then warm the motor up to operating temp and adjust them hot/warm (0.010 cold and 0.012 hot) also you can take the squirter tube off and blow some air through it to make sure all the holes are opened up,sorry I didn't look at this sooner Christmas and all you know.
