The X5 SAV Forum
Old 10-05-2004, 08:28 AM
King's Avatar
King King is offline
Mein Auto: X5 4.4i
Question 'Key is in ignition...'
I messed something up during my NAV retrofit...
I keep getting this message in the dash when exiting the vehicle...even though the engine is turned off and I pull the key out! I can not seem to lock/unlock the doors either with the key.
I don't have any of the NAV or radio components plugged in and I pulled the terminal on the battery for half an hour, but still have this problem. Checked all fuses too.
Sounds like a re-coding issue??
Old 10-05-2004, 06:25 PM
X5M5 X5M5 is offline
Official Bangle Hater
Mein Auto: '01 X5 4.4i, '00 M5
King, it sounds like something is seriously messed up with your X5. What I can tell you is that the databus in our vehicles is highly sensitive to wire tapping and wire quality. In other words, while installing your wiring for the NAV you inadvertantly crimped a wire or frayed one, this could be the cause of all your problems.
I'm not saying you did, but this is just too bizarre otherwise.
'01 X5 4.4i Topaz Blue/Black, '00 M5 Anthracite/Red, '06 Z4M Red/Black, '05 Acura RL White/Tan, '12 X6 3.5i
Similar Threads
Incompetent dealer serviceľ need key memory help ivan308 General BMW Questions 8 12-25-2003 10:37 AM
occasional problem of turning the ignition key z0mb13 3 Series & 4 Series 14 07-16-2003 08:34 PM
Horn does not work w/o key in ignition? Matthew330Ci General BMW Questions 6 05-10-2003 09:23 PM
Help! Key Memory & seats binaryfarms 3 Series & 4 Series 11 03-23-2003 02:32 PM
Key memory observation. cwa 3 Series & 4 Series 6 10-09-2002 04:06 PM
