E30 (1982 - 1993)
Old 12-16-2013, 06:42 AM
e30forlife1717 e30forlife1717 is offline
Mein Auto: 87 325e
Throttle body swap
How much hp would you get if you put a throttle body off of a 325i on to my 325e. The 325i throttles boby is like twice as big and it will bolt right on.
Old 12-16-2013, 07:33 AM
Dromey Dromey is offline
Aspiring dolphin
Mein Auto: '90 325iC
Not a lot... if you already have one, I'd put it on to increase the throttle response. Otherwise, save your money for more important things.
Old 12-16-2013, 07:50 AM
Mein Auto: 87 325e
Re: Throttle body swap
I had one laying around I put it on my 325e and a cold air intake and I think it added more then a few hp
Old 12-16-2013, 09:58 AM
Mein Auto: 87 325e
What about putting the intake manifold from a 325i to the 325e
Old 12-16-2013, 07:38 PM
Aspiring dolphin
Throttle body swap
Again, pretty much no horsepower gain if you do that. Most people just put on a CAI for the faint sucking air sound it makes. I think it's too much labor trouble for the actual gain, which is pretty much nothing.
Old 12-17-2013, 08:09 PM
downhiller's Avatar
livin large
unless youre building a super eta/boosting........dont bother
Old 12-18-2013, 03:07 AM
toybuilder's Avatar
toybuilder toybuilder is offline
Mein Auto: 89 325i 2dr&DucatiMonster
What you need is the whole head from a 325i ,then your headed in the right direction.If you do that you really need to use the later fuel injection/ECU as well.The heads on BMWs flow so well it's almost pointless to port and polish them unless your building a full race motor.So there's not much you can do to increase air flow with out adding forced induction,and if you do that you better fortify your motor ,at least if you want to have it stay together for more than a week.
Old 06-28-2014, 10:27 PM
mdarosa54's Avatar
mdarosa54 mdarosa54 is offline
Mein Auto: 1987 325e
So basically u guys are saying the is head and tb won't help out my e at all ?
Old 06-28-2014, 10:29 PM
mdarosa54's Avatar
Because I feel like my buddy's stock is , is much more responsive than my 86 325e I need some advice what can I do to help my e keep up with the is , would bigger injectors and the is tb help along with a ebay chip in my ecu ?
Old 06-29-2014, 05:46 AM
downhiller's Avatar
livin large
in order to make it worth while, you gotta change the head, intake and exhaust manifold and ecu over to the i/s.
or put a 4.10 diff in
Old 06-29-2014, 06:27 AM
mdarosa54's Avatar
There is a 410 rear end on craigslist for $150 right now is that the m3 rearend
Old 07-02-2014, 09:02 PM
logantv logantv is offline
Mein Auto: 1990 325is m20/260
IIRC it was for the iX to help make up for the extra weight off the line.
Old 07-02-2014, 09:04 PM
Your trade off will be higher RPMs on the interstate.
Old 07-03-2014, 07:30 AM
BMWFatherFigure's Avatar
Old School
The 'e' head has smaller valves than the 'i' head and the ecu is different (IIRC). Block is the same. Again, IIRC, the 325e is really 2.7 but made as a high torque low rever??
Current:
E38 Parts Car
Previous:
Old 07-03-2014, 04:45 PM
mdarosa54's Avatar
I want higher RPMs in 5th gear
