Old 12-16-2013, 01:29 PM
4ocious 4ocious is offline
Mein Auto: 2011 135I MS 6MT, 2006 X3
Install Front Strut Brace?
I'm getting a handle on what mods I want to perform and was thinking of installing the OEM front strut brace. Is it worth the cost and did you notice any difference? I had one on my M3 and M5 and although small I did feel it made the front-end a little more rigid.
Current:
11 BMW 135i Grey/Blk Cpe/M-Sport/6MT/BMW Perf. Mods/Cusco Brace/K&N's/All OEM Options/PPK ECU
10 Porsche Cayenne GTS/Design Ed 3 (1/100)/K&N's/2nd Cat Delete/425hp
06 BMW X3, Bluewater/Tan/K&N's/XM (Wife's)
Old 12-17-2013, 10:02 PM
1zamboni 1zamboni is offline
Mein Auto: 2013 E93 & 2014 F30
I had mine installed and noticed the front end is much more rigid, not so sure if the BMW front strut will fits 135i.
2014 F30 335i Melbourne Red
2013 E93 M3 Melbourne Red
2012 E93 Space Gray (Retired BMW buy back)
2009 E82 ( Sold )
2006 E90 ( Sold )
2001 E46 ( Sold )
My next vehicle would be a Zamboni
Old 12-18-2013, 04:49 AM
I was wrong, BMW makes an OEM front strut brace for the 128 not the 135. What's the difference? Thanks for your response.
Current:
Old 12-18-2013, 02:49 PM
ModBargains IV's Avatar
ModBargains IV ModBargains IV is offline
Mein Auto: e92, e82, e46, e39
If you are looking for a strut brace for your 135i, you can look into the Cusco Front Strut Brace for the 135i chassis:
A car's chassis naturally flexes from inputs from the road - corners, uneven pavement, etc. Adding a strut brace will help strengthen the chassis rigidity translating into better handling and stability.
Cusco has a really information article on the benefits of the strut brace:
http://www.jdm-option.com/eng/pr_CUSCO/towerbar.html
Frank Kim | Frank@Modbargains.com | (714) 582-3330 ext 8003
Hours: Monday - Friday 8:00AM-6:00PM, Saturday 8:00AM-5:00PM (PST)
| Our Blog
Old 12-18-2013, 05:11 PM
John Davis John Davis is offline
Mein Auto: 2004 BMW 330ci
I put a Turner front strut brace in my 2004 330ci a couple of months ago. I haven't really noticed a difference (or sometimes I think there's a slight difference, and then I wonder if that's my imagination).
However, my car is merely a daily driver, and I drive pretty conservatively. If you drive more aggressively than I do, perhaps it makes a difference.
2004 330ci w/ sport package, 6 spd manual
Modifications: 3.46 differential, Pedalbox throttle signal amplifier, Active Autowerke performance software, Bilstein HDs, B&M short shifter, Zhp shift knob
2006 650i convertible in stratus gray
Old 12-31-2013, 05:28 PM
Roland135i Roland135i is offline
Mein Auto: BMW 1 coupe 135i
OEM strutbar fits also on a 135i N54. I got one. The only thing that is a bit in the way, is an airco cap. But you can click it out of its holder and lower it abit.
Old 01-01-2014, 05:07 PM
Thanks for getting back to me. I still can't figure why an OEM brace would fit a 128 and not a 135. However, I'm still going to purchase one and find out. I've decided to slowly turn my 135 into a street/track car and this is one of the track items I need.
Current:
Old 01-01-2014, 10:50 PM
Yeah, it will fit alright. Just need to do 2 things:
1: Unclip airco hose and strap down with a tie-rap:
2: put a rubber ring or something simular between the strut and the top of the oem filterbox. When I put the strut on, it had some clearance.
But later on, when the engine was warm, it sometimes just touched the strutbar, resulting in a vibration heard throughout the car, that was pretty annoying
Goodluck
Old 01-25-2014, 10:02 AM
Installed Cusco Strut Brace
I installed my Cusco strut brace yesterday but due to the VERY COLD weather here in VA I haven't had the opportunity to see if it makes a (any) difference. But, it does look good and fits very well. Installation was relatively easy once I figured out I had to remove all the nuts on all sides as well as the nuts that secure the OEM brace (to lift it) so I could access the nuts underneath. I also had to loosen (Allen wrench) the brace on both sides to ensure it lay flat on the strut. Once I accomplished these tasks the brace slid right in and I was able to secure it to the strut towers without any problems. BTW, the protective wrap is a pain to remove!
Next, ECU re-flash and maybe a LSD.
Current:
Old 02-06-2014, 06:17 AM
The horrible weather in Northern VA finally moderated and I was able to get my 135i on the road to determine if my recently installed Cusco strut brace made a/any noticeable handling difference. IMO, it does, although not a great difference due I think in part to my OEM M-Sport suspension. Although front end handling seems flatter, stiffer and with less lean than before (in normal DD conditions) I can see where it would make a noticeable difference on the track. So, if you're going to occasionally track your car like I plan to you should install a strut brace. If you have no tracking plans it's a nice addition, worth the money, but not a necessity - JMO.
Current:
