Old 12-16-2013, 06:29 PM
flux45 flux45 is offline
Mein Auto: 2011 335xi
Dirt in 3rd brake light area
Greetings. I did a quick search on this and found nothing.
I noticed today while refueling that there is a noticeable amount of dirt inside of the 3rd brake light "housing". Further, it seems like someone has stuck something in there. I don't know if this was kids messing around or someone attempting to clean it (just bought the car), but is there a way to easily remove this housing and clean the inside? My skill level is "i can change a flat tire" and I am new to BMW's.
PS, happy to be here.
Old 12-16-2013, 08:33 PM
335IoTwnTrbos's Avatar
335IoTwnTrbos 335IoTwnTrbos is offline
Official 'Fest GIF Guy
Mein Auto: 2008 E92 335i
Hey Flux,
You should be able just to pull the cover off from the liner area and clean the dirt. i had some dead critters in mine after I bought my car. Let us know if you need anything more concrete. Just go slow and steady when you try to pull it off and you should be fine.
"When you can't run, you crawl... and when you can't do that, you find someone to carry you."
|100,000mile Club (E92)2008 335i SGM "Io"- Cobb Tuned |6AT|Premium|Sport|
|AE Performance CBE|AR Design DPs|CF GTR Vented Hood|Cobb AP V2|SP Lowering Perches (F)|M3 FCAs|VRSF 5" FMIC|
|BMS DCI|Niche Targa M129 18x8/18x9.5|BMS Spacers 10mm/15mm|BP Drilled/Slotted Rotors|BP Ceramic Pads|
|Forge DVs|CP-e Upper CP|VRSF Lower CP|BMS Cowl Delete|MR Front Strut Bar|BMS OCC|Custom CA License Plate|
Old 12-17-2013, 08:54 AM
Wow, that was super easy. Took off the brake light cover in the headliner with a simple pull, then unlatched the brake light itself and dusted it out. Nice and clean now!!
For anyone else that comes across this thread, here are some additional resources:
http://www.pelicanparts.com/BMW/tech..._Replacing.htm
