Old 12-16-2013, 08:44 PM
lionard lionard is offline
Idiot BMWer
Mein Auto: 2007 BMW335i sedan
Exclamation coolant flush DIY for 2007 BMW335i sedan
Try to make a coolant flush for my 2007 BMW335i Sedan,however, after jacking up my car and remove engine splash shield, I can't even find the drain plug of the radiator as well as hose clamp of thomostat. Does any expert can help me? Many thanks.
ID:	412756   Click image for larger version
ID:	412757   Click image for larger version
ID:	412758   Click image for larger version
ID:	412759   Click image for larger version
Old 12-18-2013, 02:04 PM
jburke4689 jburke4689 is offline
Mein Auto: 2007 335i
You need to remove the intercooler to get access to the radiator drain. Very easy.
Old 12-18-2013, 09:01 PM
Idiot BMWer
Can you write here the procedure to remove the intercooler? Preferably with photos.
Old 12-18-2013, 10:36 PM
ctuna ctuna is online now
Mein Auto: 325xi wagon
FYI this may be of some help.
http://www.e90post.com/forums/showth...radiator+fluid
This one if for and n52 but I think its pretty similar.
From
http://www.e90post.com/forums/forumdisplay.php?f=16
Old 12-19-2013, 03:27 AM
Banned
Mein Auto: 2007-335 HTC
If you are going to work on your own car you best get a Bently manual, just used mine to replace the serpentine belt and idler rollers and tensioner It was a big help, Costly book but well worth the price. There is also a lot of general information in the book that you should know too.
Old 12-23-2013, 06:44 AM
Augster Augster is offline
Mein Auto: M1A1 Abrams
And thermostat is up above the water pump, this making it completely inaccessible without removing the water pump, though I'm wondering why you are asking about getting to one of its hose clamps. If its simply to drain any residual coolant, you can remove the thermostat-to-water pump hose at the water pump.
2008 335i Sport Sedan AT
Old 12-23-2013, 10:13 AM
Check this: Better than pictures
Old 12-23-2013, 03:00 PM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
Most people just pull that plastic pipe on the bottom of the water pump and that will get you about 2/3 of the coolant, if you want to do the extra work of removing the intercooler, that will get you most of the rest out of the drain on the radiator. I just do it a little more often and just do the pipe on the pump and get 2/3rds but it takes no time to do that!
2008 335i Vert Montego/Saddle/Grey Poplar
2013 Mercedes C63 AMG Obsidian Black/Black
2016 X5 M-Sport Mineral White/Mocha Design Package/Fineline Oak
