Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series & 4 Series > E21 (1975 - 1983)
E21 (1975 - 1983)
Old 12-18-2013, 02:24 AM
j-moff j-moff is offline
J-moff
Mein Auto: 1979 e21 323i
clutch fluid leak
hey im new to bmw and I have just got a 1979 bmw 323i and I need to find a leak in my line for the clutch fluid I have not fully assessed the leak yet any ideas?
Old 01-16-2014, 09:07 PM
BMWFatherFigure's Avatar
Old School
Pull back the boots and see if you have fluid leaking from slave or master. If there is any fluid rebuild as required. Bleed the system then stand on the pedal while some one watches for leaks. That should cover it.
Current:
E38 Parts Car
Previous:
Old 01-19-2014, 10:36 AM
loki1120 loki1120 is offline
Mein Auto: 83 320i (everyday)
E21's clutches are wonderfully simple If the clutch works I'd replace the line from the reservoir to the master cylinder since the brakes and clutch share a common reservoir it can also be a brake leak.. either way I'm betting on the cloth covered hose going to the master cyl. Oh the master cyl will leak on your foot and floor (it'll get worse in the cold weather) inside the car and the slave will leak on the ground.
323i, bmw, e21
