E46 (1999 - 2006)
Old 12-19-2013, 06:52 PM
gregs0427 gregs0427 is offline
Mein Auto: 2007 335i 2003 330ci
Water Pump HELP!!
so i just did my expansion tank and water pump and had everything hooked up leak free and went to drive and a couple miles down the road it started overheating.... i checked the lower hose and it was still "cool" as if the pump isnt pumping but there is a bunch of pressure built up in expansion tank what could be the problem? T stat was fine this morning....I pulled new WP and put old one back in and same problem.....!!! Help
Old 12-19-2013, 07:03 PM
G. P. Burdell's Avatar
G. P. Burdell G. P. Burdell is offline
Rambling Wreck
Mein Auto: E46
Did you bleed the air from the system when you refilled with coolant?
Old 12-19-2013, 07:06 PM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
This. ^^
Sounds like your pump is fine. The lower hose should be cooler as the coolant has run through the radiator and is sucking back into the engine. It's the coolest point of the circuit.
Wiki has bleed procedure in the cooling section. http://www.bimmerfest.com/forums/sho...05#post8014505
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
Old 12-19-2013, 07:45 PM
bleed did it ithinl
Old 12-19-2013, 08:14 PM
ahull's Avatar
Originally Posted by gregs0427 View Post
bleed did it ithinl
Check the level manually a few times over the next few days and adjust as needed. Do NOT overfill it or something will rupture. You'd be surprised how many people get it wrong.... do it the right way and you'll have no problems.
Old 12-19-2013, 11:17 PM
GoForthFast GoForthFast is offline
Mein Auto: '04 330Ci 6-speed
Read about the proper way to bleed, and repeat several times over a few cycles.
Old 12-20-2013, 02:25 PM
SDpnoy SDpnoy is offline
E46Fanatics
Mein Auto: BMW 330Ci
+1
This most likely the cause. What coolant did you use btw?
Old 12-21-2013, 09:57 PM
RobinHood RobinHood is offline
Mein Auto: 2003 325xi
Is this typical? Like if I fill properly, and drive and the coolant light comes on and goes back off, but no overheating, is this just kinda the system working out air pockets? and repeating this a time or two is this normal?
Old 12-22-2013, 04:49 AM
ahull's Avatar
It's usually not necessary if its done right the first time. But may be necessary if a large amount of air is introduced without a complete drain n fill. If you have an intermittent light it's probably just a little low. Check on a cold engine.
Old 12-22-2013, 08:52 AM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Re: Water Pump HELP!!
I'm betting the op didn't have the heat on full blast. Without doing that it won't get the air out of the heater core while bleeding.
Sent from my HTC One X using BimmerApp mobile app
