E46 (1999 - 2006)
Old 12-20-2013, 07:04 AM
SaintE46 SaintE46 is offline
Mein Auto: BMW E46
Help E46 2001
Hi
When driving and the car gets warm, the dash beeps and displays -40.00'C, what does that mean?
Where can I find an air mass sensor @ a good price?
Old 12-20-2013, 10:27 AM
cvx5832 cvx5832 is offline
Mein Auto: 325Ci, 325Cic, C300
1.) Ambient air temp sensor is broken or disconnected.
2.) You don't say what E46 you have. If that's a 325, the Hyundai MAF sensor (VDO) is the best deal. Or just furiousmethod.com it.
Old 12-20-2013, 11:45 AM
Mein Auto: BMW E46
Thank you, tell me where is that sensor located and how simnple is it to replace it?
Does it effect the performance in anyway tho?
Bmw E46 318i 2001
Old 12-20-2013, 01:13 PM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
It does not affects performance. Usually in bottom plastic shield in front of drivers tire.
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
Old 12-20-2013, 01:44 PM
Mein Auto: BMW E46
That would explain a lot, my sister drove up a curb and cracked my rim aswell as messed up that plastic shield. So that sensores probably gone
Thank you.
Old 12-20-2013, 11:04 PM
Wulff Wulff is offline
Mein Auto: 2001 325i
Mine was missing as well, just 2 wires hanging down in that area, I bought a new one but haven't installed it. What is it for? Everything seems normal with it missing.
My cars: 2001 325i w/5-speed. Mostly stock. I also have a 1988 Monte Carlo SS with 406 cid, TPI and 6-speed when I want to blast the rice into the weeds.
Old 12-20-2013, 11:42 PM
Jmiller160 Jmiller160 is offline
Mein Auto: 2003 BMW 325ci
Help E46 2001
I have a 03 325ci and my sensor was gone when I bought my car. As far as I can tell it helps with the auto air conditioning system. On my car once it got wet and started reading -40 degrees it would shut my a/c off... All I did was cut the wire and taped it up really good to stop the annoying warning lol
Old 12-21-2013, 04:23 AM
ahull's Avatar
Yeah the sensor can affect a/c performance to clarify earlier comment. Sometimes taping the wires doesn't work.
Old 12-21-2013, 07:44 AM
GoForthFast GoForthFast is offline
Mein Auto: '04 330Ci 6-speed
Here is both a close up of the sensor, and a pic of the underbody of the car with the sensor location showing at the upper right-hand corner of the pic.
Name:	Temp Sensor.jpg
ID:	413398   Click image for larger version
Old 12-21-2013, 09:20 PM
engineear engineear is offline
Tells you the outside temperature. It beeps to warn you it's cold...possible icy conditions. Mine beeped last week. It showed 39 degrees...in Phoenix!
