E46 (1999 - 2006)
Old 12-20-2013, 02:01 PM
2000323 2000323 is offline
Mein Auto: E46
Loss of power - please help
I recently had a problem with my throttle body sticking closed and decided to clean it myself, all seemed to go well and it was pretty dirty but now that it is back together I have a serious loss of power especially at low rpm.
I checked the disa valve and I suspect it is not 100% but the pin is still in it and it functioning.
I removed the idle control valve and I am not sure how to test it, I know its not sticking because when I hold it in my hand and twist it the valve turns very freely, maybe even to much so. if I connect the cable and turn the key on it vibrates and the valve still seems to be able to move by me shaking it. It also sounds like i might have a bad vacuum leake but I cant find anything.
And my intake boots are in good shape, not cracked or broken.
Any thoughts...
Old 12-20-2013, 02:06 PM
Fast Bob's Avatar
Fast Bob Fast Bob is online now
Keeping it surreal
Scan the codes and see what turns up....
The road goes ever onward....
(R.I.P. Jever)
Old 12-22-2013, 06:33 AM
Mein Auto: E46
No codes at all.
Also to add to that it takes a couple seconds of cranking to start and it occasionally stalls and dies but it seems to idle just fine.
last time I drove it before working on it the throttle body got stuck and the only way I got it to open was to spray throttle body cleaner directly into the intake with the motor running, I know I shouldnt but it got me home and thats what I needed. The can stated that it was safe for mass airflow sensor but could it have damaged it anyways?
Old 12-22-2013, 09:47 AM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
Originally Posted by 2000323 View Post
No codes at all.
Sounds more like a fuel pressure issue. Does not always throw a code. Filter is a 60k miles item and pumps average 10 years. Could have a leak in vacuum to fuel pressure regulator on the filter.
You can loan a pressure checker from Autozone and check pressure. e46 wiki has pressures: http://www.bimmerfest.com/forums/sho...05#post8014505
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
Old 12-24-2013, 09:05 AM
Mein Auto: E46
I have already replaced the fuel pump and filter in the last year so I am going to assume that's not the issue but I will check on the vacuum leak. Where is the fuel pressure regulator located on a 2000 323i.
Also I am not unable to accept this as coincidence but I question why this would start immediately after working on my throttle body, before when it wasn't sticking closed I had plenty of power. I am willing to wager that I did something inadvertently that has caused a problem and like I said I will check everything I can but I think it will be related to some part of the intake or other component that I was working around.
Old 12-24-2013, 09:13 AM
Mein Auto: E46
Also I ordered a new Mass Airflow Sensor just to rule that out because when it is disconnected it seems to start easier, however I have not driven the car with it disconnected.
Is the fuel pressure regulator located directly in front of the filter?
Edit - Never mind I found it
http://www.realoem.com/bmw/showparts...37&hg=13&fg=10
Old 12-28-2013, 07:11 PM
Mein Auto: E46
So I replaced the mass airflow sensor and took a close look around and turns out that I cracked a plastic 90 degree turn fitting for the vacuum line that runs down under the car (I expect that it does feed the fuel pressure regulator) and I was able to remove that fitting and figure out something else that worked OK and now it is running 100%
The idea of the fuel pressure being the cause was sort of right but my fuel pressure regulator is not in or on the filter like suggested, turns out I was right that it was just something that I did inadvertently while I was under the hood.
I consider myself a decent mechanic but boy was I surprised that I had broke that plastic fitting, stuff like that under the hood must be getting brittle with age.
Old 12-29-2013, 05:42 AM
ahull's Avatar
Glad you got it figured out. Yeah the regulator is on the filter on the 325/330s. I forget it was different on earlier models. I agree the plastic gets brittle. One of the problems with the CCV hoses. If the valve doesn't clog the plastic in the hoses crumbles.
