Oli Level sensor issue - Bimmerfest - BMW Forums
Old 12-22-2013, 11:41 AM
Eric2684 Eric2684 is offline
Mein Auto: 2006 325i
I have an 06' 325i E90. The low oil level warning light came on 2 days in a row recently. When I checked the oil level, it took several minutes to appear, but eventually showed that the oil was at the maximum amount recommended. I think the sensor just needs to be replaced, but Im trying to avoid spending $200 on a new one. Does anyone know if it can be fixed by maybe spraying Brake Cleaner or Carb & Choke cleaner on it and re-installing it, using gasket maker to ensure it does not begin to leak oil? I had an issue with the VANOS sensors 2 years ago, and after spraying them with a ton of brake cleaner and re-installing them, then began working well again with no issues sense.
Old 12-22-2013, 02:01 PM
R1200 R1200 is offline
Mein Auto: 328XiT and R1200C
I recall early failures of the oil level sensor would result in people adding more and more oil making the problem worse. The rule was add one litre and no more especially if your car is not visibly burning or losing oil.
The sensor is made of a couple of concentric tubes to measure conductance so I doubt that cleaning it will help. I would check the amount of oil that comes out at the next oil change to decide if the sensor needs replacing. It would only be a serious issue if you run the full length of time and distance between changes. I change more often and given that there is a lot of oil in the sump and I drain out the amount that I put in, I probably would not need the oil level sensor.
On the other hand, just replace it for peace of mind.
Don
328XiT Sonora
Old 12-22-2013, 03:02 PM
bluskye bluskye is offline
Mein Auto: 2006 330i / 2007 X3
I would check if you are really loosing/burning oil or not. I had that same situation on my E46, and it turned out I was really loosing oil.
Old 12-22-2013, 06:39 PM
BMWCCA 149159
Mein Auto: 17Ridge/14JGC/ 17Outback
Assuming the oil sensor is at fault and you are not low it happens that extended oil changes and cold weather contribute to confuse the sensor. Many times changing the oil will remedy the problem...
Old 01-18-2014, 05:57 PM
wilt wilt is offline
Mein Auto: 2011 328i
Thank God that BMW still has a dipstick on your engine...the F30's don't! I had a 2001 E46 whose oil level sensor would come on a few seconds after starting the engine, then would stay lit for just under a minute and then go out. I quickly discovered, via the dipstick, that the oil level sensor was falsely lighting up the warning light. I drove it for almost 3 years before I bothered to change that sensor! Old fashioned dipsticks do not fail like electronics. Someone at BMW had their head in a dark place when deciding to leave out the dipstick on the turbocharged 4-banger of the F30.
Old 01-18-2014, 09:55 PM
Mein Auto: '06 AW 330xi
There is no dipstick on any E9x
Old 01-18-2014, 11:42 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Pretty close - capacitance with oil as the dielectric. As oil breaks down / oxidizes / pollutes, the capacitance changes and is read by the chip in the bottom of the sensor. Sensor signal sent on bus to ECU. 3 sensors on one: Temp, level; condition. The first is a replaceable RTD; second are concentric tube capacitance sensors.
The upper part of the probe senses level as he surface area of concentric tubes immersed in oil changes with level. The bottom part is oil condition as it's always submerged; constant surface area.
Issue may be the Resistance Temperature Device - they're cheap - try RTD replacement first!
Old 01-18-2014, 11:44 PM
Still no convincing explanation for dipstick deletion....y'know wilt, the capacitance probe might be called a stick....
Old 01-29-2014, 12:39 PM
davenova davenova is offline
Mein Auto: 2009 335i Convertible
The oil level sensor in my 2009 335i went bad after 18 months and was replaced under warranty. Now it has failed again - the dealer quoted $500 to replace it! I agree that omitting the dipstick was a bonehead idea. There should be a dipstick to use as a backup to determine the oil level. Not all automation is progress.
Old 01-29-2014, 01:05 PM
Very unusual. How do they know it's bad, or was that a mech's WAG?
And what can go wrong? Unlikely the construction's bad....maybe the seal....most likely electronics, but that might also be a wiring issue.
Old 01-29-2014, 03:18 PM
jburke4689 jburke4689 is offline
Mein Auto: 2007 335i
The conspiracy theorist in says that BMW doesn't want people dropping by the dealer for 1/2 quart top offs between oil changes. So they get to control the messaging through the Check Control process. Who knows. The dip stick is a comforting backup to the oil sensor. Most American cars have both.
Old 01-29-2014, 04:11 PM
My 2001 E46 certainly had both. With...
  • the cheaper plastic interiors of the F30, and
  • the omission of the dipstick in the E90 as well as
  • omission of the flashlight (in the later E90) and
  • omission of the the jack and spare, and cheapening of the toolkit, and
  • elimination of the ashtray and lighter outlet in the post-facelift E90,
...the trend strongly seems to be BMW cost reduction.
Old 01-29-2014, 05:08 PM
ptrcd003 ptrcd003 is offline
Mein Auto: 328i LCI
Well, a lot of it is just logical. The RFT eliminated the need for a spare. Without a spare, no need for a toolkit. Also no need for a flashlight, since you won't be changing tires in the dark. In terms of the ashtray, my LCI has both an ashtray and a lighter outlet.
Old 01-29-2014, 08:10 PM
Agree about RFT no longer needing a jack and lug wrench, but what about the user manual telling owners about the crank for closing the moonroof, but BWM no longer makes nor sells the tool?! Dumb!
And I guess the apparent total lack of mechanical skills in the new group of BMW owners means that no one knows or cares about a set of pliers or some open end wrenchs to tighten nuts.
2011 E90's don't necessarily have lighter and ashtray in the front...I have put my Garmin GPS mount in that spot, so I didn't mind. I could sort of understand removal of ashtray in back seat (how often do we have smokers in the backseat?!).
Old 01-30-2014, 12:10 AM
And I guess the apparent total lack of mechanical skills in the new group of BMW owners means that no one knows or cares about a set of pliers or some open end wrenchs to tighten nuts..
How many San Francisco residents does it take to change a light bulb?
4
One to pour the wine
One to call the caterer
One to heat the hot tub
One to call the electrician
C'mon now, wilt....pliers are, like multimeters and oscilloscopes, specialty tools a professional would be expected to use.
Old 01-30-2014, 08:57 AM
Sorry, I forgot about needing to attend dental school to figure out the use for pliers
Old 01-30-2014, 09:19 AM
ramblinman ramblinman is offline
Mein Auto: 2008 335
I had some erratic readings on my oil level, which I thought indicated a bad sensor. I contacted Mike Miller, the tech expert at BMWCCA. He said that the way the dealers check the sensor is to drain the oil, measure the amount of oil drained. If the sensor level and the oil measurement are the same, the sensor is ok. If not, they replace the sensor.
Rather than pay an inflated price for a diagnostic fee and then have to pay for a replacement, I just changed the sensor. It's around $150 from Tischer on line.
Replacing the sensor is an easy fix. You have to drop the aerodynamic plastic panel underneath the engine bay. The sensor is in a recess in the pan near the oil drain bolt. It's held in place by 3 nuts. They are easy to take off. Disconnect the wire connector. Remove the nuts, R and R the sensor, and torque the nuts. Bentley manual has the torque values for 2 step torque tightening. They are low values, so use a 3/8 torque wrench.
When I first replaced the sensor, the oil level seemed to be low. I let it sit overnight and it came up to full on the sensor the next day. It's been fine since. I think that when you refill the oil with the oil temp at ambient temps, some of it is trapped in the head, or it takes a while for the oil to fill up the space in the sensor when it is first installed. I'd rather be a little low than overfill. I generally put in 6.5 quarts, run the engine, check the level and top off if needed.
Old 02-02-2014, 09:00 PM
MikeTerp MikeTerp is offline
Mein Auto: 2007 BMW 328 (E90)
This thread is truly LOL worthy. The BMW computer oil level sensor is a totally unnecessary joke. I change my own oil on my 07 E90 328. At first, I would always put in seven quarts as stated. Then, after some comments on these threads about oil sensors, I put in six just to see what the oil sensor would say - FULL UP! Next change I put in 5.5 and got the same computer output. I topped up in both cases, but the clear message is that the sensor may be lying and that hooking everything up to a computer is not always a good idea. And for those who say that they are too busy, or too lazy to open the hood to access a dipstick (which I pray we see again), I would only say that if you are too lazy to raise the hood, you are also most likely NEVER to access the oil level requiring a series of clicks on the iDrive.
BMW: Give us back our dipsticks.
Old 02-03-2014, 11:57 AM
DPST option for $250 on the 2015 model year cars. No retrofit possible in E90s or F30s prior to MY2015.
Old 02-03-2014, 12:17 PM
Westech's Avatar
Westech Westech is offline
Mein Auto: '00 Z-3 '06 325ixT
BMW oil level sensors are known to fail. Replacement part is about $161. www.getbmwparts.com Change it next time you change your oil. Sleep well.
Old 02-05-2014, 10:56 AM
BMW, GIVE BACK our dipsticks!!!
