Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > E60 M5 (2006 - 2010)
Old 12-27-2013, 01:03 PM
kanass69 kanass69 is offline
Mein Auto: E60 M5
Would really appreciate some help
HEy Guys
Long time reader first time poster!! I am the lucky and proud owner of a E60 M5, year 2006. I live in Dubai and so far the car has behaved nicely!!
However, for the past week or so, i have had an electrical issue that the mechanics havent been able to fix. Basically, when i try and start the car, i get all the normal indications, re lights, HUD..when i turn the key, i get just a clicking sound and no start. There are no codes, no warning lights but the HUD indications go blank as i turn the key, then when i release they come back. If i jump the start the car subsequently, it runs fine for that day. However, if i leave the car for a day without driving it, the same problem returns. The BMW boys, made me change the battery and they also had the car for a few days but couldnt find the fault. I am now not really feeling confident with them, as they are charging me!!
Was wondering if anyone else has had the same issue or may have some ideas on areas i should check? The mecahnics reckon the battery drain when car is switched off is 0.250..not sure if that is an indication of anything as i am not possessing many brain cells!!
Any help or advice would be greatly appreciated
Cheers and thanks alot...
Old 05-02-2014, 04:42 PM
Way2fast Way2fast is offline
Mein Auto: 2006 M5
How old is your battery? Sounds like it is going bad and not holding a charge. You should get it checked out
Old 05-06-2014, 04:35 PM
White94RX White94RX is offline
Mein Auto: E39 540
So you did install a new battery or not? If you did, and it still goes dead, you have a draw. If you didnt replace it, start there.
BMW Level 1 Master Certified
2001 BMW 540i
Old 06-07-2014, 10:09 PM
MBEA5t MBEA5t is offline
Mein Auto:
Every new battery have to be registered in car computer or it will never hold charge.
Start there and see what happens!
Take it to a dealership!!!!
Or blow your money by hammer mechanics!
Old 08-18-2014, 02:23 AM
chefevan chefevan is offline
Mein Auto:
Originally Posted by kanass69 View Post
HEy Guys
I had same thing happen its your key fab. You might have got it wet or any moisture would mess it up and then when you put it in the ignition the computer cant read it and it shuts down!
