Old 12-29-2013, 08:55 PM
jamesching jamesching is offline
Mein Auto: bmw 525i 2005 e60 sedan
pros and cons of bov
pros and cons i want knowledgable answers now just people that like bovs and people that dont giving me their side of the story. pros and cons. thanks. blow off valve were talkin
Old 12-30-2013, 05:02 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Here's all you need to know: If turbos unmodified, stock BOV does job silently. Aftermarket does same job not silently, noticed by those nearby, CHiPs or no.
Old 12-30-2013, 07:56 AM
bad
This is a nad answer considering u said "this is all u need to know" I didnt ask what I need to know i asked all pros and cons doesnt look like u gave me much bout intakes nd bovs
Old 12-30-2013, 09:22 AM
Mein Auto: '06 AW 330xi
I think it really only boils down to preference.
The stock diverter valves are in place for noise and emissions reasons. It does not make noise, it just recirculates unused air back into the intake stream to be reused, reducing emissions.
BOVs will make noise, obviously, because they don't recirculate unused air back into the intake stream, they blow it off to atmosphere.
They make hybrid, BOV/diverter valves that do sort of both.
Old 12-30-2013, 09:47 AM
bear-avhistory's Avatar
bear-avhistory bear-avhistory is online now
2014 435M-Sport/MPPK
Mein Auto: 2014 435M-Sport/MPPK
Which part are you missing? If you want to make noise get a BOV if not leave it stock.
Kevin
CURRENT:
2018 BMW 440M-Sport MPPK/MPE 8ZF
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
470 WHP of BURBBLES
HOME FROM PAINT
Old 12-30-2013, 10:24 AM
Well jamesching, those are the pros and cons. Like I said: Unmodded turbos. It's a simple pressure relief. There ya go - Google that!
Old 12-30-2013, 11:37 AM
What r some ways it can harm or hell the engine also I. can pass emissions with in right in jersey
Old 12-30-2013, 11:49 AM
Good Lord. It can't harm your engine. In a basic way same as stock but open to atmosphere.
Old 12-30-2013, 12:21 PM
Then why do people with 335i say that it has...u needa calm down cal
Old 12-30-2013, 12:22 PM
You should search google and various forums. These questions have been answered before.
Old 12-30-2013, 01:56 PM
bseebeck bseebeck is offline
Mein Auto: 2013 335i Coupe M-sport
I don't know how you answered that Cal. I could barely understand what he was trying to say. Does this forum not have a spell check feature?
2013 BMW 335i Coupe M-sport - Black Sapphire Metallic/Oyster interior
Old 12-30-2013, 05:54 PM
Well, I'm fluent in Text Language.
Old 12-30-2013, 06:42 PM
ptrcd003 ptrcd003 is offline
Mein Auto: 328i LCI
Our new members seem to be getting ruder and less capable of communicating. May be time for an F30.
Old 12-31-2013, 05:47 AM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
Technically the stock diverters are a bit weak and of course just made out of plastic like half the car. Stock no real difference except noise, if you are making more boost, at some point the stock diverters can leak boost of fail and then you need a stronger part. As for noise, most BOV's just vent atmosphere, so you get the little pressure release sound - they all make different sounds, some are loud some are not so much. You can also get BOV's that will work like the stock diverters and vent back into the intake and make more noise.
2008 335i Vert Montego/Saddle/Grey Poplar
2013 Mercedes C63 AMG Obsidian Black/Black
2016 X5 M-Sport Mineral White/Mocha Design Package/Fineline Oak
Old 12-31-2013, 10:09 AM
isjoey isjoey is offline
Mein Auto: 2011 335is
Pros - Will be able to handle higher boost better than the stock BOV and noise. Will not effect emissions at all.
Cons Get a recirculating bov if you do get one - 1) If you get an atmospheric bov for just noise your drivability will go to ****! Your turbos basically need to rebuild most or all of the boost pressure when you even slightly let off the gas. 2) Use more gas
2017 M2 Alpine White | DCT | M Performance Exhaust
2011 335is | M3 suspension bits all around | Ohlins R&T | Vorshlag camber/caster plates | Wavetrac LSD | Goodridge PTFE SS brake lines | Apex PS-7 wheels
Old 12-31-2013, 01:52 PM
Pilgrim's Avatar
Pilgrim Pilgrim is offline
Car guy since 1968
Mein Auto: 2008 E91 328xi Sportwagon
And patient to a fault. My respects go out to you for your tolerance.
1983 Datsun 280ZX Turbo
2000 Jeep Grand Cherokee
2008 BMW E91 328xi Sportswagon
2009 BMW E92 328ix Coupe
Old 12-31-2013, 04:54 PM
The E9X has pretty much hit its expiration date. Nothing much new to say in quite a while.
Kevin
CURRENT:
470 WHP of BURBBLES
HOME FROM PAINT
Old 01-02-2014, 07:17 AM
RobertoCervezas RobertoCervezas is offline
Mein Auto: 2013 335i coupe
A bov will cost money and won't make your car any faster. Draws attention from all the wrong people. Doesn't sound like a good investment to me.
Old 01-02-2014, 11:13 AM
Banned
Mein Auto: 2007-335 HTC
I thought they were called Waste Gates, any excess pressure over the rated PSI on boost pressure, the waste gate would open to relieve the excess pressure, but still allow the proper PSI to still go to the intake
I think of a blow off Valve associated with pressure vessels, Like a steam boiler, Exceed the MAWP(thats maxium allowable working pressure the the valve would Pop open and let off the pressure so the unit would not blow up, and some would have to be manually reset
Old 01-02-2014, 11:21 AM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
waste gates operate on the exhaust side of the turbo, bleeding off exhaust gases when boost isnt requested. for example, when running at low load or if the boost target has already been hit.
bypass or blow off valves operate on the intake tract, they bleed off excess boost pressure post turbo. for example, if you lift off the throttle, to shift for example, the built up boost in the intake tract has to be released. hence the blow off or bypass valve.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
blow off valve 335i
