Old 12-29-2013, 09:12 PM
Blue Demon Blue Demon is offline
Mein Auto: 335i Coupe
Lowering Spring Eibach
How low should be lower my car with Eibach springs for 20 inch rims? I was thinking about .5 for the rear and 1.5 for the front. Also, would it ride bouncy on the highway? Any thoughts or suggestion on it.
Old 12-30-2013, 04:51 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Whelp, I wasn't aware that Eibach made springs for 20" rims.
But Koni makes shocks that can be matched to Eibach's. Yellow they are, and those you should buy, for shocks unmatched to springs are the road to Perdition!
Blue Demon, and you want to avoid having that handle apply to this job, which if your purchase Eibach Sport linear springs can lower your ride 1/2 - 3/4" from Sport suspension stance. See and talk to THESE FOLKS.
Old 12-30-2013, 09:42 AM
Mein Auto: '06 AW 330xi
Any ride lowered with JUST lowering springs will be bouncy.
Think about it...your stock shocks are valve for the stock springs. When you lower, you move that range and the valving becomes incorrect.
I have no comment about the 20s...well I do, but I'm not going to say it.
Old 12-30-2013, 09:49 AM
Banned
Mein Auto: 2007-335 HTC
I would believe that BMW would take into account the spring rates, shock valving and the tire side wall height when configuring the suspension
Old 12-30-2013, 09:03 PM
techietaichi techietaichi is offline
Mein Auto: '06 325i Pre-LCI
I ride H&R Sport Springs on my stock shocks and I'm not "bouncy". It was dropped by Turner Motorsports almost a year ago pretty evenly, 1.3 in the rear and 1.4 up front if my memory serves me right and I can fly like I was on a fully stock suspension. However, I do remember them mentioning that my bump stops were slightly modified, that might explain the non-bounciness. Hmm? And about those "dubs", you sure you want to do that man? 18's are spot on, 19's look good if you're conservative about the style, 20's.... You sure, you sure? Are you going to "stance" this fine German auto?
http://www.bimmerfest.com/forums/image.php?type=sigpic&userid=369805&dateline=1388122517
Old 12-30-2013, 09:59 PM
captainaudio's Avatar
Worlds Foremost Authority
If its worth doing its worth overdoing.
Drivers Club at Lime Rock
BMWCCA
Cayman Club Nor'Easters
Porsche Club of America
Sports Car Club of America
American Mural Project
Mount Washington Observatory
Old 12-31-2013, 01:44 PM
Ok, that's just bleeping ridiculous!
Old 12-31-2013, 02:25 PM
Gotcha!
Photoshop!
CA
BMWCCA
Old 01-01-2014, 03:50 PM
riviera1969 riviera1969 is offline
VELOZV
Mein Auto: 2008 BMW 335I STICK SHIFT
I have 19"
I have Eibach springs 1.5 lower in front and 1" in back, also 19" 235-35-19 in front and 265-30-19 in the back. You do change the ride depends on runflats or lower profile tires.
Old 03-08-2014, 02:34 AM
notanotherbmw notanotherbmw is offline
Mein Auto: 2007 320i e90 sedan
Im looking at the same. I put lowered springs in a Commodore with the standard struts and they are buggered now. If you think about it, the struts are for the standard height. So lowering them MUST add pressure to them and they eventually give way. I want to put MSport or HR springs in, but I really think they need the struts too. What do you think?
2007 320i sedan e90
