E90 backup camera - Bimmerfest - BMW Forums
Old 12-31-2013, 10:37 PM
BMW7_CEO's Avatar
BMW7_CEO BMW7_CEO is offline
BMW7_CEO
Mein Auto: 05 745LI 06 650i 06 330xi
E90 backup camera
Hey guys I've research all over the forums and threads about the backup camera installations and I know it needs a 12V relay to switch the voltage on the reverse light back up to 12. In my situation I'm retrofitting the wireless peak performance backup camera everything works turns when the car is on (without engine being on) but today when I started the car with the engine being on I installed the relay and it didn't do anything my reverse lights shut off as soon as I connect the other wire to the battery I don't know what is wrong or if the relay that I'm using is the wrong one or if connect it incorrectly, I don't have an Idrive either but guys please help me out thanks..
Old 01-01-2014, 05:35 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Post your wiring diagram
Old 01-01-2014, 06:50 AM
BMW7_CEO's Avatar
BMW7_CEO
E90 backup camera
The first photo it the relay that is a four pin 12v one, I used the same wire but put tape on the negatives to distinguish one another. the second photo I'm holding a wire, that wire I wired it to the battery of the car the four and fifth photos are the connections to the reverse tail light positive and negative.Click image for larger version
ID:	414969Click image for larger version
ID:	414970Click image for larger version
ID:	414971Click image for larger version
ID:	414972Click image for larger version
Old 01-01-2014, 09:41 AM
fdriller9 fdriller9 is online now
Mein Auto: '06 AW 330xi
I don't mean to offend but that is some really poor soldering.
Get a relay harness and use quick taps to splice in the harness. If the relay ever goes bad, you just pull it out then plug in a new one.
What camera kit did you get?
I leave mine powered 24/7. No issues for the past 3-4 months.
Old 01-01-2014, 09:43 AM
Google Bosch relay. It should bring up some diagrams to help you. Most will be for some kind of light wiring. It's the same
Old 01-01-2014, 11:02 AM
BMW7_CEO's Avatar
BMW7_CEO
E90 backup camera
I know it's poor soldering it's my first time doing it but I'm retrofitting the peak performance wireless backup camera and thanks ima check it out I appreciate it, if you or anyone else finds an easier way or gets how to match my setup I'll appreciate thanks guys!
Old 02-23-2014, 04:43 PM
06330ibmw 06330ibmw is offline
Mein Auto: 330i
Does anyone know if you can connect a backup camera to a e90 2006 330i. with Nav? and where do I get the Info? Thanks
Old 02-23-2014, 04:57 PM
BMW7_CEO's Avatar
BMW7_CEO
You can but you would have to get it coded to the navi after words once it's connected
