Old 01-01-2014, 03:43 PM
eliu eliu is offline
Mein Auto: e90 325xi
325xi can't start up
So I'm on vacation and I stall out at the hotel going up a hill and my 325xi manual 2006 won't start back up. Jump starting didnt work but we were able to bump start/jump the clutch and drive around fine. The engine doesn't crank and all you hear is a slight click when you try to key start it but all lights/radio works. My question is that is this a for sure sign my starter is busted or could their be other culprits? I've never had problems that would of indicated starter problems in the past; any chance this is electrical like a weak battery or blown fuse? I have to drive home and I'm evaluating if I should bring it in here where I'm on vacation or bump jump it home and take it to a local mechanic.
Old 01-01-2014, 05:17 PM
ctuna ctuna is offline
Mein Auto: 325xi wagon
Battery Voltage is the first thing to check
If you are on your original battery an its and 06 0r 07 you
are due for one.
A good battery should measure around 12.5.
And your running voltage should be around 14.5
Also the IBS (infernal battery system its suppose to be
the intelligent battery system ) can cause strange symtoms.
These cars don't jump easily by the way.
I always feel better getting things worked on at home
where I know the mechanics and there reputations plus if there
is something wrong with the repair I have some place that
might rectify the problem.
Also if you do a battery replacement do not use battery back up
especially through the OBD port it will blow a fuse and the symptom
is no Dash display or readings . And if somebody else does it make sure they know
this.
