Ticking when cold start .. - Bimmerfest - BMW Forums
Old 01-02-2014, 08:38 AM
335i_tt_2009 335i_tt_2009 is offline
Mein Auto: 2009 335i TT
I have a 2009 335i sedan and when I do a cold start especially when it is actually cold outside it makes a ticking sound on the driver side under the intake piping... it sounds to me like its a sensor or something of that sort.. Anyone else experience this or would have any input on what it could be??
Old 01-02-2014, 09:11 AM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
If you search around the most common source of that noise is that HPFP pressure valve, at low RPM's it bleeds pressure back to the tank and makes a ticking noise - seems all cars eventually get it and it just becomes normal at idle warm or cold. Mine took about 18k before it started to happen.
If it is this, if you raise the RPM to 2000 or so, the noise will go away - if that is the case, this is the issue and you just get to live with it - if RPM's don't change anything, it could be something else, but by the location you are describing, you are describing this issue.
2008 335i Vert Montego/Saddle/Grey Poplar
2013 Mercedes C63 AMG Obsidian Black/Black
2016 X5 M-Sport Mineral White/Mocha Design Package/Fineline Oak
Old 01-02-2014, 09:23 AM
Thanks!! I'll try raising the rpms to about 2k and see if it still exsists.
