best lowering options for my 2011 335i xdrive - Bimmerfest - BMW Forums
Old 01-02-2014, 10:34 AM
markus8291 markus8291 is offline
Mein Auto: 2011 BMW 335i xdrive
I have done lots and lots of searching but found nothing specific to what I'm looking for.
Basically I want the gap between the wheels and the wheel well gone. I have the M-Package on my car and just want it to look like a non X-Drive 335i with the M-Package. Is there a way to do this without hurting anything? I'm not gonna track my car so it doesn't have to be super high performance and I still want a fairly nice yet sporty ride.
Any ideas on what to go with?
Old 01-02-2014, 11:22 AM
ModBargains.com's Avatar
ModBargains.com ModBargains.com is offline
Mein Auto: E92 335i, F82 M4
Vehicle suspension is something that Iím extremely passionate about. I wouldn't suggest pairing up an after market spring with an OEM shock. Paring up an aftermarket spring with more aggressive spring rates will cause your OEM non-sport or sport shocks to wear out over time. This is due to the fact that OEM shocks are simply not meant to handle the more aggressive spring rates. Think of it this way, you're putting a shorter spring with a longer shock body. The shorter springs will cause the shocks to compress to its maximum setting every time you hit a bump due to the longer travel distance. What this can cause is what's known as bump steer and jarring of the ride (what youíre experiencing). This is what for the most part affects ride quality.
Let's break this down in terms of cost. You'll spend about $230-300 bucks for aftermarket springs, another $250-300 for an installation, and another $65-$125 for an alignment. When your OEM sport or non-sport shocks blow your going to have to spend another $700-800 on shocks, another installation fee, and another alignment. If you calculate that all together, you would saved a whole lot more mone5y doing it right the first time around. With that being said, I would most definitely recommend that you go with a coilover system and do it right the first time.
The answer is simple; you get what you pay for when it comes to vehicle suspension. As such a crucial component of your vehicle, suspension is definitely something you do not want to cheap out on. A coilover suspension basically gives you a matched lowering spring and shock absorber combination with the added benefit of adjustable ride height and spring rates through a moveable spring perch or perches. Coilovers are to your car's advantage by reducing unsprung mass, increasing suspension travel, and allowing the car to be corner balanced.
I'd recommend that you check out the the KW V1 xi coilovers. It will give you the ability to fine tune the car and adjust the ride height to your preference. It's also perfect for an everyday street driven car and will be comfortable for street driving. Below are a couple installed pics for you to check out.
Alan Wei | Alan@ModBargains.com | (714) 582-3330 ext. 8006
We Specialize In: BMW M3 Wheels | BMW Brakes | BMW Suspension | BMW M3 Parts | VMR Wheels |
Remus Exhaust | HRE FlowForm
Hours: Mon - Fri 8:00am-6:00pm | Sat 8:00am-5:00pm
Check out the Blog for daily updates!
Old 01-02-2014, 11:26 AM
Thanks for the reply. I definitely wasn't trying to just go the cheap route. I spent a lot of money on the car so I wanna do it right. I guess that was the point I was trying to get across in the post. I will check out the link to the coilovers you posted. Most important thing for me is not to hurt anything when I lower the car and like I said, all i want to do is close that big wheel well gap on the xdrive and give it the standard 335i look.
