E46 M3 (2001-2006)
Old 01-03-2014, 06:01 PM
noorcaliii noorcaliii is offline
Mein Auto: 2003 E46 M3
New to Bimmerfest, confused about burning oil
Hello everyone,
My name is noor and I'm new to Bimmerfest.
Just for the record, mommy and daddy did not but my car. I saved up the money, took me two years, but the E46 M3 is worth every penny.
It was a hunt, but I finally managed to buy my 2003 Alpine White M3 a few months ago. Has aftermarket rims on at the moment, just waiting to buy some tires for the original 19s.
I just had a question, besides the fact that the oil (10W-60) is exclusive to only Bmw dealerships, (and maybe Mercedes) I am continuously adding oil to my car. The oil light comes on about once every month. And my big question is that, is it normal for my car to be burning this much oil? (1 Liter a month)
Please comment if you know it if you have the same issue! Thanks again guysClick image for larger version
ID:	415428Click image for larger version
ID:	415429Click image for larger version
ID:	415430Click image for larger version
ID:	415431Click image for larger version
Old 01-08-2014, 08:46 AM
89gtcs 89gtcs is offline
Mein Auto: 2011 Mustang GT
First off, congrats! That's a beautiful car.
Do you drive aggressively on a regular basis? When you downshift, do you rev match each time? Are there any noticeable leaks anywhere/is your oil pressure normal? From what I've heard, some oil consumption is normal for these engines. Also, what is your oil change interval and what kind of oil do you use? Castrol TWS 10W-60 seems to be the most highly recommended oil.
Lastly, have you considered running an oil separator/catch can? I don't know if this is common (my background is Ford/GM engines) but I run a catch can on my 5.0 mustang engine and it collects between 1/4 and 1/2 inch of oil per oil change depending on my driving.
2011 Mustang GT Premium
Old 01-21-2014, 10:55 AM
JKRIT JKRIT is offline
Mein Auto: '03 525i
Noor: Ten year old BMWs tend to have oil leaks from various places, particularly the valve cover gasket and the oil filter housing gasket. The VCG leaks are pretty obvious and may leak onto the exhaust manifold so you smell it too. The OFHG leaks are much harder to spot on the side of the block behind the alternator. Check everywhere for oil leaks before you presume that the oil is being "burned."
'03 525i Sapphire Blu/Grey, SP, Nav
'03 530i Sterling Gray/Blk, SP
'02 525it Titanium Silver/Grey, SP
'02 325it Orient Blu/Grey, SP, Nav
Old 01-21-2014, 03:54 PM
@89GTCS Thanks a lot I appreciate it! And yes I do drive a bit aggressively; however, I don't think that would burn one liter every two weeks. Also, I do tend to drive normal too, for the sake of the maintenance and safety. So I don't think it could be that but maybe an oil leak?
Old 01-21-2014, 03:55 PM
Originally Posted by JKRIT View Post
Noor: Ten year old BMWs tend to have oil leaks from various places, particularly the valve cover gasket and the oil filter housing gasket. The VCG leaks are pretty obvious and make leak onto the exhaust manifold so you smell it too. The OFHG leaks are much harder to spot on the side of the block behind the alternator. Check everywhere for oil leaks before you presume that the oil is being "burned."
Thanks a lot. I'm thinking it could be an oil leak... BMWs are notorious for their oil leaks and more for how secretive they could be lol. Anyways, I'll look into it but the only smell I get is the clutch when I put it into fast shift mode. Other than that, everything seems to check out...
Old 01-21-2014, 07:20 PM
kardboard kardboard is offline
Mein Auto: E46 M3
Sounds like a leak.
Just to be a little more sure... don't drive aggressively. Drive like a granny, rev match as smoothly as possible (or if you have an smg keep it on automatic) for two weeks and see if the cars consumption of oil is consistent to what you were experiencing before.
I just picked up a manual transmission M3 and thankfully it isn't eating oil like you are reporting. Mine also has 115k miles.
Old 02-07-2015, 08:27 PM
X3-terrestrial's Avatar
X3-terrestrial X3-terrestrial is online now
Aficionado
Mein Auto: '05 X3, '02 M3, '91 E30
Originally Posted by noorcaliii View Post
Hello everyone,
Please comment if you know it if you have the same issue! Thanks again guysAttachment 415428Attachment 415429Attachment 415430Attachment 415431Attachment 415432
HiNoorcaliii,
How many miles? If you had a leak that size, it would be really obvious at that pace, your car would be marking its territory everywhere you park! That or if it were :burning" it, you would be smoking blue smoke all over your neighbors.
M engines are notorious for being oil thirsty...some more than others, with a few reporting very little to no oil use. Oil "consumption" if compression tests are ok (meaning engine internals are fine) has been narrowed down to either a clogged oil separator, or worn valve stem seals.
The first being a $40.00 part and easy to replace yourself and the second a more involved mechanical job. I'd start replacing the oil separator and go from there.
Oil Separator part #11157840446
Please keep this post updated with your findings for the sake of information.
Good Luck!
"If everything seems under control, you're just not going fast enough"
-Mario Andretti.
___________________
River City Bimmers BMW CCA
2005 X3 3.0i ZPP, Htd seats, Htd strng, Black Sapphire on Terracotta.
2002 ///M3 Coupe, Steel Gray Metallic on black leather, HK, three pedals.
1991 E30 325ic, AW, Black Leather, Black top, Three Pedals.
